2012-05-04, 18:40
Has anyone been able to use one the of the roku 2 gaming remotes with xbmc? It seems like it should be possible since they run on bluetooth.
(2013-10-05, 00:14)verismo Wrote: [ -> ]i know this is an old post but bump, wondering the same thing
http://www.amazon.com/Original-Roku-Remo...oku+remote is the remote
<?xml version="1.0" encoding="UTF-8"?>
<!-- This file contains the mapping of keys (gamepad,remote and keyboard) to actions within XBMC -->
<!-- The <global> section is a fall through - they will only be used if the button is not -->
<!-- used in the current window's section. Note that there is only handling -->
<!-- for a single action per button at this stage. -->
<!-- For joystick/gamepad configuration under linux/win32, see below as it differs from xbox -->
<!-- gamepads. -->
<!-- The format is: -->
<!-- <device> -->
<!-- <button id="#">xbmc action</button> -->
<!-- </device> -->
<!-- To map keys from other remotes using the RCA protocol, you may add <universalremote> blocks -->
<!-- In this case, the tags used are <obc#> where # is the original button code (OBC) of the key -->
<!-- You set it up by adding a <universalremote> block to the window or <global> section: -->
<!-- <universalremote> -->
<!-- <obc45>Stop</obc45> -->
<!-- </universalremote> -->
<!-- Note that the action can be a built-in function. -->
<!-- eg <button id="e">ActivateWindow(Favourites)</button> -->
<!-- would bring up Favourites when the button with the id of 6 is press. In this case, "Menu" -->
<!-- Button Ids: -->
<!-- 'id' is the button ID used by SDL. The button ids recognized from your remote appears -->
<!-- in /var/log/syslog on the ATV2 for each button pressed and when debug mode is enabled -->
<!-- Use your log to discover and map custom buttons to actions. -->
<!—- Roku remote derived from apple tv remote —->
<keymap>
<global>
<joystick name=“Roku”>
<!-- plus --> <button id="u">Up</button>
<!-- minus --> <button id="d">Down</button>
<!-- left --> <button id="l">Left</button>
<!-- right --> <button id="r">Right</button>
<!-- center --> <button id="s">Select</button>
<!-- menu --> <button id="e">Back</button>
<!-- hold center--> <button id="7">Fullscreen</button>
<!-- hold menu --> <button id="3">ContextMenu</button>
<!-- old buttons for ATV1 <2.2, used on OSX -->
<!-- hold left --> <button id="c">Left</button>
<!-- hold right --> <button id="8">Right</button>
<!-- new aluminium remote buttons -->
<!-- play/pause --> <button id="12">PlayPause</button>
<!-- Additional buttons via Harmony Apple TV remote profile - these are also the learned buttons on Apple TV 2gen-->
<!-- pageup --> <button id="x">PageUp</button>
<!-- pagedown --> <button id="y">PageDown</button>
<!-- pause --> <button id="15">Pause</button><!-- work? -->
<!-- play2 --> <button id="16">Play</button>
<!-- stop --> <button id="17">Stop</button>
<!-- fast fwd --> <button id="18">FastForward</button><!-- work? -->
<!-- rewind --> <button id="19">Rewind</button>
<!-- skip fwd --> <button id="20">SkipNext</button>
<!-- skip back --> <button id="21">SkipPrevious</button>
<!-- Learned remote buttons (ATV1 >2.3) -->
<!-- Play --> <button id="70">Play</button>
<!-- Pause --> <button id="71">Pause</button>
<!-- Stop --> <button id="72">Stop</button>
<!-- Previous --> <button id="73">SkipPrevious</button>
<!-- Next --> <button id="74">SkipNext</button>
<!-- Rewind --> <button id="75">Rewind</button>
<!-- Forward --> <button id="76">FastForward</button>
<!-- Return --> <button id="77">OSD</button>
<!-- Enter --> <button id="78">ShowVideoMenu</button>
<!-- few gestures from Apple's iPhone Remote (ATV1 > 2.3 ?) -->
<!-- SwipeLeft --> <button id="80">Left</button>
<!-- SwipeRight --> <button id="81">Right</button>
<!-- SwipeUp --> <button id="82">Up</button>
<!-- SwipeDown --> <button id="83">Down</button>
<!-- FlickLeft --> <button id="85">Left</button>
<!-- FlickRight --> <button id="86">Right</button>
<!-- FlickUp --> <button id="87">Up</button>
<!-- FlickDown --> <button id="88">Down</button>
</joystick>
</global>
<Home>
<button id="4">ActivateWindow(Favourites)</button>
<button id="3">ActivateWindow(shutdownmenu)</button>
</joystick>
</Home>
<FullscreenVideo>
<button id="u">VolumeUp</button>
<button id="d">VolumeDown</button>
<button id="l">StepBack</button>
<button id="r">StepForward</button>
<button id="7">Pause</button>
<button id="e">Stop</button>
<button id="s">OSD</button>
<button id="3">Fullscreen</button>
<button id="c">Rewind</button>
<button id="8">FastForward</button>
<!-- pageup --> <button id="x">ChapterOrBigStepForward</button>
<!-- pagedown --> <button id="y">ChapterOrBigStepBack</button>
<!-- SwipeLeft --> <button id="80">StepBack</button>
<!-- SwipeRight --> <button id="81">StepForward</button>
<!-- SwipeUp --> <button id="82">BigStepForward</button>
<!-- SwipeDown --> <button id="83">BigStepBack</button>
<!-- FlickLeft --> <button id="85">Rewind</button>
<!-- FlickRight --> <button id="86">FastForward</button>
<!-- FlickUp --> <button id="87">BigStepForward</button>
<!-- FlickDown --> <button id="88">BigStepBack</button>
</joystick>
</FullscreenVideo>
<FullscreenLiveTV>
<button id="l">ChannelDown</button>
<button id="r">ChannelUp</button>
<!-- pageup --> <button id="x">ChannelUp</button>
<!-- pagedown --> <button id="y">ChannelDown</button>
</joystick>
</FullscreenLiveTV>
<FullscreenRadio>
</joystick>
</FullscreenRadio>
<Visualisation>
<button id="l">SkipPrevious</button>
<button id="r">SkipNext</button>
<!-- SwipeLeft --> <button id="80">SkipPrevious</button>
<!-- SwipeRight --> <button id="81">SkipNext</button>
<!-- FlickLeft --> <button id="85">SkipPrevious</button>
<!-- FlickRight --> <button id="86">SkipNext</button>
</joystick>
</Visualisation>
<SlideShow>
<button id="u">ZoomIn</button>
<button id="d">ZoomOut</button>
<button id="l">PreviousPicture</button>
<button id="r">NextPicture</button>
<button id="7">Info</button>
<button id="s">Rotate</button>
<!-- SwipeLeft --> <button id="80">PreviousPicture</button>
<!-- SwipeRight --> <button id="81">NextPicture</button>
<!-- FlickLeft --> <button id="85">PreviousPicture</button>
<!-- FlickRight --> <button id="86">NextPicture</button>
</joystick>
</SlideShow>
<ScreenCalibration>
<button id="s">NextCalibration</button>
</joystick>
</ScreenCalibration>
<VideoOSD>
<button id="7">Back</button>
</joystick>
</VideoOSD>
<VideoMenu>
<button id="3">OSD</button>
<button id="7"/>
</joystick>
</VideoMenu>
<MyVideoLibrary>
</joystick>
</MyVideoLibrary>
<MyVideoFiles>
</joystick>
</MyVideoFiles>
<PictureInfo>
</joystick>
</PictureInfo>
</keymap>
(2015-06-02, 12:10)trilliam Wrote: [ -> ]I'm having trouble identifying joystick name on my computerhttp://pastebin.com/KUk3eKNA
i will post a long in the next hour
