Full Version: Problems with sound on HDMI connection
I've just bought an Acer Revo R3700 and installed xbmc 11.10.
I have successfully connected to my home network and I am playing music from another PC in the house. So far so good. Smile
The problem I'm having is that I can't hear the music through the TV, which is connected to the XBMC box by HDMI cable. NOTE: I've checked the cable, which is OK (i.e. it works when I use it to connect the Sky box to the TV). Sad
When I try and play a track on I get a message saying "Failed ti initialize Audio device. Check your audio settings") .... these are:
Audio Output - HDMI
Speaker Configuration - 2.0
Boost volume level on downmix - enabled
- Dolby Digital (AC3) capable receiver - enabled
- DTS capable received - enabled
Audio Output Device - HDA NVidia - hdmi - 3 (ALSA)
Passthrough output device - HDA NVidia - hdmi - 3 (ALSA)
The TV is a Samsung UE46D7000
I'm new to this linux malarky, so any assistance would be welcomed.
Cheers
Graham
Well, no need to respond now.
I installed ubuntu desktop 12.04 and everything is now functioning properly.
I may install xbmc on top of ubuntu, but not sure if that is really necessary.
Cheers
G Wink
