Full Version: Menues lag sometimes on fast computer
Sometimes menues lag in xbmc 11.0. 8-30 fps and my gpu usage gets up to 100%.
Doesn't matter if I have recently reinstalled windows or not.
Its resolved by restarting the computer only.
I got a very fast computer so its not normal slowdowns, got an 4.5 ghz core i5 and a 7970 @ 1125/1575.
Anyone know why it lags like this, seems like bug in coding.. I mean 100% gpu usage with the worlds fastest gpu and i get pictures showing at a rate for 8 fps ^^
Edit: Got another issue to but with aeon nox skin. My mousecursor is replaced with a huge box saying "mouse is not supported" Can I change that box into a mouse courser?
Aeon nox skin.doesn't support a mouse. Update your drivers... hopefully you'll get a fix, in the meantime... switch off DXVA you have plenty of horsepower.
Enable Dirty regions (wiki)
I have a similar problem reported here: http://forum.xbmc.org/showthread.php?tid=129185
When I enter the movie library, the CPU peek to a 100% for about 5 seconds or so
Bump, has nothing to do with dirty regions. I got a fast computer.
