good work. if you send me a, i will apply it to the git repo!!
(2012-08-31, 21:07)mindrunner Wrote: [ -> ]good work. if you send me a, i will apply it to the git repo!!
sure, here you go:
mod
i added a delay of 20 seconds, to give my system some time. may be useful to make that a configurable option for the masses
regards,
maikl
So there is a new release with more settings
-enable service
-startup delay
-enable visualisation
-visualisation delay
i did not check all options in combination. please test your favourite config and tell me if it is working.
i think i have to learn how to debug this small piece of code...
i shpuld react much faster if you stress me with an email aditionally. i did not get any notifications from this forum?!?
try to subscribe again. hope this is working now.
mindrunner
Can I put the line in PartymodeAutostart.py, only for one song to get background music in xbmc.
I need background music not partymode,I think your script it is perfect for that.Of course if it's possible.
Best Regards
It should be possible, but you might also do by another way.
It should be possible to tell xbmc that it should use a particular playlist instead of all songs fuer partymode.
Just put a one-song-playlist in there and you should be fine.
I cannot give further instructions right now, because i do not have a running xbmc right now!
mindrunner
Thank you for your response.
Just do not understand, how to avoid other songs from music library.
I am glad that it is possible,please if you have time to write a short tutorial.
Best Regards
