2012-05-06, 23:07
I've searched around a bit, but didn't get a fix on my problem. I've seen people with similar symptoms, but none of the solutions worked.
Here is the XBMC log with the Airplay related logs. In this log, I start XBMC, then immediately try to Airplay a photo from my iPhone 4S, then I try to Airplay music from my iPhone 4S. As you can see, the logs show the photo being Airplayed but there is no trace whatsoever of the music Airplay.
- Airplay is turned on.
- Photo Airplay from iPhone 4S is working.
- Video Airplay from iPhone 4S is working.
- Audio (Music) Airplay from iPhone 4S or iTunes is not working.
- Tried multiple iDevices (iPhone 4, iPad 3), same symptoms.
- Tried setting up a password for Airplay, no solution.
- iTunes shows the Airplay logo as soon as XBMC is started, but doesn't show XBMC as an output option, just "Computer" which is the actual iMac I'm working off.
22:41:43 T:139635045025664 NOTICE: -----------------------------------------------------------------------
22:41:43 T:139635045025664 NOTICE: Starting XBMC (11.0-PRE Git:Unknown), Platform: Linux (Ubuntu 12.04 LTS, 3.2.0-24-generic x86_64). Built on Apr 29 2012
22:41:43 T:139635045025664 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
22:41:43 T:139635045025664 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
22:41:43 T:139635045025664 NOTICE: special://masterprofile/ is mapped to: /home/htpc/.xbmc/userdata
22:41:43 T:139635045025664 NOTICE: special://home/ is mapped to: /home/htpc/.xbmc
22:41:43 T:139635045025664 NOTICE: special://temp/ is mapped to: /home/htpc/.xbmc/temp
22:41:43 T:139635045025664 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
22:41:43 T:139635045025664 NOTICE: Local hostname: HTPC
22:41:43 T:139635045025664 NOTICE: Log File is located: /home/htpc/.xbmc/temp/xbmc.log
22:41:46 T:139635045025664 INFO: AIRPLAY Server: Successfully initialized
22:41:46 T:139633547540224 NOTICE: Thread AirPlayServer start, auto delete: false
22:41:46 T:139633765619456 DEBUG: CZeroconfAvahi::doPublishService identifier: servers.airplay type: _airplay._tcp name:XBMC (HTPC) port:36667
22:41:46 T:139633765619456 DEBUG: CZeroconfAvahi::addService() named: XBMC (HTPC) type: _airplay._tcp port:36667
22:42:02 T:139633547540224 DEBUG: AIRPLAY Server: New connection detected
22:42:02 T:139633547540224 INFO: AIRPLAY Server: New connection added
22:42:02 T:139633547540224 DEBUG: AIRPLAY: got request /server-info
22:42:02 T:139633547540224 INFO: AIRPLAY Server: Disconnection detected
22:42:02 T:139633547540224 DEBUG: AIRPLAY: got request /photo
22:42:02 T:139635045025664 DEBUG: Loading the current image special://temp/airplay_photo.jpg
22:42:02 T:139634117945088 DEBUG: Finished background loading special://temp/airplay_photo.jpg
22:42:05 T:139633547540224 DEBUG: AIRPLAY: got request /stop
22:42:05 T:139633547540224 DEBUG: AIRPLAY: sending event: stopped
22:42:05 T:139633547540224 INFO: AIRPLAY Server: Disconnection detected
22:42:20 T:139633547540224 DEBUG: AIRPLAY Server: New connection detected
22:42:20 T:139633547540224 INFO: AIRPLAY Server: New connection added
22:42:20 T:139633547540224 DEBUG: AIRPLAY: got request /server-info
22:42:20 T:139633547540224 DEBUG: AIRPLAY: got request /stop
22:42:20 T:139633547540224 INFO: AIRPLAY Server: Disconnection detected
22:42:26 T:139635045025664 INFO: Previous line repeats 1 times.
------- I exit XBMC at this point -------
22:42:29 T:139635045025664 DEBUG: CZeroconfAvahi::doRemoveService named: servers.airplay
22:42:29 T:139633547540224 DEBUG: Thread AirPlayServer 139633547540224 terminating
