Not sure if things like this are allowed to be requested, if not please just remove this post as it's my first...
IF it's fine to request this can I ask could somone please provide a plugin for the following site:-
http://mypremium.tv/
I have this app on my iPhone but I don't get all the channels, however when I use the website they work?
Lashed
you can find this in the Sportsdevil add-on
(2012-05-07, 12:28)RustyTheCat Wrote: [ -> ]you can find this in the Sportsdevil add-on
Thank you for your input, however I have that add-on and none of the streams work...
I'm hoping to find an alternative solution until SportsDevil is fix for ATV2...
i'm also using an ATV2 and have no problem with Sportsdevil and mypremium.tv. [/align]
(2012-05-07, 15:39)RustyTheCat Wrote: [ -> ]i'm also using an ATV2 and have no problem with Sportsdevil and mypremium.tv. [/align]
Can you assist me please?
hello,
I just go into Sportsdevil, to TV, and then to MyPremium. Usually, I try ALL streams to get one that works, 2 is usually a good one. Give it a go, or is there something else?
check that Sportsdevil is : (Current) Version: 1.7.4.3.1
http://xbmc-development-with-passion.goo...ortsDevil/
(2012-05-07, 20:33)RustyTheCat Wrote: [ -> ]hello,
Thanks.. I'll give that ago and see if I have better luck
(2012-05-07, 21:31)jay-arr Wrote: [ -> ]Hi
You can try this addon http://forum.xbmc.org/showthread.php?tid=121180. It has mypremium.tv streams in their "Live TV Channels" section.
I've added this but had no luck with the streams, it doesn't help that currently I'm using WiFi for my ATV2... I'll be sure to give this another go.
