2012-05-07, 13:20
2012-05-07, 13:20
2012-05-07, 20:20
EDIT: MUCH better (and free) solution below
2012-05-07, 22:27
(2012-05-07, 13:20)blekm Wrote: [ -> ]I have this one
and If I press Menu it opens Front Row. Instead I want to open XBMC?
Any idea of how to do that? Is that possible?
Now I must open XBMC using keyboard / mouse and after that I can do all with remote control.. just missing the opening of the XBMC?
Any idea?
Go under Settings -> System -> Input Devices and make sure that "Allow start of XBMC using the remote" is enabled. When you exit XBMC then pressing the Menu button on the Apple Remote will start XBMC again.
2012-05-08, 06:25
(2012-05-07, 22:27)winestock Wrote: [ -> ]Go under Settings -> System -> Input Devices and make sure that "Allow start of XBMC using the remote" is enabled. When you exit XBMC then pressing the Menu button on the Apple Remote will start XBMC again.
Holy crap, how did I not see this before. I even took a picture of that exact setting for use on the XBMC Wiki. Now I just feel silly :)
In any case, very awesome.
2012-05-08, 10:48
just done, but still doesn't start
2012-05-08, 21:58
(2012-05-08, 10:48)blekm Wrote: [ -> ](2012-05-07, 22:27)winestock Wrote: [ -> ]Go under Settings -> System -> Input Devices and make sure that "Allow start of XBMC using the remote" is enabled. When you exit XBMC then pressing the Menu button on the Apple Remote will start XBMC again.
Exit XBMC and open the AcitivityMonitor utility app. Do you see under processes an entry called XBMCHelper?
2012-05-09, 02:31
(2012-05-08, 21:58)winestock Wrote: [ -> ](2012-05-08, 10:48)blekm Wrote: [ -> ](2012-05-07, 22:27)winestock Wrote: [ -> ]Go under Settings -> System -> Input Devices and make sure that "Allow start of XBMC using the remote" is enabled. When you exit XBMC then pressing the Menu button on the Apple Remote will start XBMC again.
yes, it's there. I just killed it, but the menu button still does nothing..
2012-05-09, 19:07
(2012-05-09, 02:31)blekm Wrote: [ -> ](2012-05-08, 21:58)winestock Wrote: [ -> ](2012-05-08, 10:48)blekm Wrote: [ -> ]just done, but still doesn't start
You don't want to kill off XBMCHelper as it is what processes the Apple Remote key presses. Try renaming your ~/Library/Application Support/XBMC folder to something other then XBMC. Now run XBMC, enable "Allow start of XBMC using the remote", exit XBMC and then press the menu button on the Apple Remote. XBMC should re-start running.
2012-05-10, 02:30
I don't have the XBMC folder under /Mac/Library/Application Support.. it should be there?
2012-05-10, 14:36
(2012-05-10, 02:30)blekm Wrote: [ -> ]I don't have the XBMC folder under /Mac/Library/Application Support.. it should be there?
The '~' refers to your user account. The Library folder in your user account maybe hidden. To get to it, hold down the option-key while clicking on the Go menu, then select Library. A finder window will open where you now have access to your Library folder.
2012-05-10, 17:07
ok, find. I done all your advise but still doesn't start.. uff, never mind, I will start the program by mouse / keyboard and the use the remote control
2012-05-11, 14:39
FYI, any time I've changed my setup in Settings -> System -> Input Devices -> "Allow start of XBMC using the remote", I've had to restart my Mac Mini before the changes take effect.
This was the case with Plex, too. Before restarting it would launch Front Row; after restarting, it would launch Plex/XBMC.
2012-05-12, 04:55
I've restarted several times, but still nothing happen,
2017-05-10, 20:17
Kodi (XMBC) has to be in Applications folder in order the Menu button to start the app.
