Full Version: [XBMCbuntu]No menu sound over optical 5.1
Hi guys,
I'm trying to set up my sound over spdif. I have unmuted everything like described in this thread: Click
When I follow post 4 in this thread, I get only sound in movies and no menu sound. Sound in XMBCbunt fails too.
I had it working once with this settings: Audio & passthrough output where set to Xonar DG - iec958 - 0(Alsa) but when reboot menu sound was gone again.
I have set no asound.conf nor a .asoundrc. Do I have to set this? Found this only in threads on setting up HDMI, what do I have to put in for optical connection?
aplay -l:
xbmc@HTPC:~$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC889 Analog [ALC889 Analog]
  Subdevices: 0/1
  Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 1: ALC889 Digital [ALC889 Digital]
  Subdevices: 1/1
card 1: DG [Xonar DG], device 0: Multichannel [Multichannel]
  Subdevices: 1/1
card 1: DG [Xonar DG], device 1: Digital [Digital]
  Subdevices: 1/1
card 2: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
aplay -L
xbmc@HTPC:~$ aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
default:CARD=PCH
    HDA Intel PCH, ALC889 Analog
    Default Audio Device
front:CARD=PCH,DEV=0
    Front speakers
surround40:CARD=PCH,DEV=0
    4.0 Surround output to Front and Rear speakers
surround41:CARD=PCH,DEV=0
    4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=PCH,DEV=0
    5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=PCH,DEV=0
    5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=PCH,DEV=0
    7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=PCH,DEV=0
    HDA Intel PCH, ALC889 Digital
    IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=PCH,DEV=0
    Direct sample mixing device
dmix:CARD=PCH,DEV=1
dsnoop:CARD=PCH,DEV=0
    Direct sample snooping device
dsnoop:CARD=PCH,DEV=1
hw:CARD=PCH,DEV=0
    Direct hardware device without any conversions
hw:CARD=PCH,DEV=1
plughw:CARD=PCH,DEV=0
    Hardware device with all software conversions
plughw:CARD=PCH,DEV=1
default:CARD=DG
    Xonar DG, Multichannel
front:CARD=DG,DEV=0
    Front speakers
surround40:CARD=DG,DEV=0
surround41:CARD=DG,DEV=0
surround50:CARD=DG,DEV=0
surround51:CARD=DG,DEV=0
surround71:CARD=DG,DEV=0
iec958:CARD=DG,DEV=0
dmix:CARD=DG,DEV=0
dmix:CARD=DG,DEV=1
    Xonar DG, Digital
dsnoop:CARD=DG,DEV=0
dsnoop:CARD=DG,DEV=1
    Xonar DG, Digital
hw:CARD=DG,DEV=0
hw:CARD=DG,DEV=1
    Xonar DG, Digital
plughw:CARD=DG,DEV=0
plughw:CARD=DG,DEV=1
    Xonar DG, Digital
hdmi:CARD=NVidia,DEV=0
    HDA NVidia, HDMI 0
    HDMI Audio Output
dmix:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 0
dsnoop:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 0
hw:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 0
plughw:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 0
Thank you very much for any help.Blush
Regards, fritz222
Make a check: edit xbmc-standalone script in usr/bin and add "sleep 8" at the beginning of it. I found that on my ion system it resolved the same problem. It looks like xbmcbuntu needs some time to load something for proper working of xbmc-standalone startup script. Eight seconds of additional booting time works for me like a charmSmile i tested it on two different systems with optical output.
Ok thank you for that advise, I'll give it a try this evening. Smile
I found out what the problem is but I'm not able to solve it.
Alsa changes the order of sound playback devices:
Once my soundcard has the number 0 and after rebooting it has the number 1 or 2. So the order of my 3 playback able cards change randomly after reboot. Is there a possiblity to avoid that?
EDIT:
xbmc@HTPC:~$ cat /proc/asound/cards
0 [PCH            ]: HDA-Intel - HDA Intel PCH
                      HDA Intel PCH at 0xfbff4000 irq 43
1 [NVidia         ]: HDA-Intel - HDA NVidia
                      HDA NVidia at 0xfaffc000 irq 17
2 [DG             ]: CMI8786 - Xonar DG
                      C-Media Oxygen HD Audio at 0xde00, irq 18
I tried to add the all of the following options at the end of /etc/modprobe.d/alsa-base.conf:
  • options snd-cmi8786 index=0
  • options snd-xonar_dg index=0
  • options snd-dg index=0
And I tried all of them with CAPS too.
I appreciate any help.
Regards, fritz222
Any ideas?
You might need something like
alias snd-card-0 snd-cmi8786
alias snd-card-1 snd-hda-intel
http://www.alsa-project.org/main/index.p...-usb-audio
That didin't worked. It's not a usbsoundcard.
But I was able to set the order according to this guide:
That didin't worked. But I was able to set the order according to this guide: Link
But I'm still not able to set the menusounds. Moviesound works on nearly every passthrough setting.
And I have a few error logs in my user directory. These error logs contain:
GNU nano 2.2.6      File: xbmc_crashlog-20120515_214004.log
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Tue May 15 21:40:04 CEST 2012
XBMC Options:
Arch: i686
Kernel: Linux 3.0.0-16-generic #29-Ubuntu SMP Tue Feb 14 12:49:42 UTC 2012
Release:
Would be great if someone could help me.
This is how I have my system setup. Works for me on all the distributions I've tried, Debian, (L)Ubuntu, Linuxmint LMDE and currently Crunchbang.
I have a TV (HDMI) and monitor (HDMI) connected to this PC via an NVidia card. PC > Receiver > TV. Sound disabled in the BIOS.
Could you try it, you can remove it if it doesn't work.
Install pulseaudio also pavucontrol to control sound settings if needed.
Add / modify /etc/asound.conf
pcm.pulse {
    type pulse
ctl.pulse {
    type pulse
pcm.!default {
    type pulse
ctl.!default {
    type pulse
And insert into /etc/pulse/default.pa
load-module module-alsa-sink device=hw:0,7
Make sure you change 'device=hw:0,7' to your device
In XBMC I have
Audio Output Device set to default and Passthrough Output Device set to 'Custom' and 'hw:0,7' - use your settings from above.
Good luck
Rick
