2012-07-04, 09:12
I've been away for some time but here are my modified version of the french strings as there was some unnecessary abrevations, missing accents, inconsistency and some other stuff.
French strings
French strings
(2012-07-06, 19:34)quebert Wrote: [ -> ]I'm not sure if this is a bug in this skin but when I change my TV shows to the banner view it still uses the posters so they look very off, sorry I don't have a screen shot (not at home) I can post one later. I have all my shows done up
etc
I manually changed a few of the thumbs to the posters, and they look great, but when I switch to any non banner view they look all stretched out again. Apparently it's defaulting to folder.jpg regardless of which view you select. Is this normal?
(2012-07-07, 23:49)Chokladkakan Wrote: [ -> ]If the name of an episode is long enough not to fit, it will naturally move across. However, is said name has letters with descenders in it, the descenders will mysteriously stay put while the rest moves.
(2012-09-18, 12:55)newcoda Wrote: [ -> ]In viewing TV shows or movies - if I got to the previous folder/back icon and then move back over movies or shows Welo will no longer show video details at the bottom of the screen. I have to restart Welo to get it back. I had Eden 11 stable and just tried the most recent nightly (couldn't install Welo on this actually).
As far as I know I have the most recent version of Welo -- it says it is updated 1.0.4
Also how can I check the IP XBMC is using inside Welo?
(2012-09-18, 23:31)idoru17 Wrote: [ -> ]I launch xbmc, go straight to TV shows (the view is poster (fixed) :
then right arrow x times to reach the end of the shows, everything is fine :
so, left arrow x times to scroll back to the beginning until the parent folder and on to this thumb, then one right arrow (or as many as I want) : no more TV Show information
PS : Whatever the view is, when scrolling, either directions, as soon as the parent forder thumb (or the two points for lists views) is accessed then the next entry loses the information displayed in the bottom right of the screen. And of course the same goes for movies !
(2012-09-28, 15:23)newcoda Wrote: [ -> ]Idle curiosity, but when is the hopeful window of release for the update?
