Full Version: xbmc crash on startup (can't kill process)
I've been having this weird problem,
When ever I launch xbmc for the first time everything works ok, but when I start it again after a while, xbmc stays at logo screen (V11.0 EDEN) and it never starts, I also can't close the program, nor use task manager to end process nor Force kill the process, it starts consuming CPU up to a point I need to restart PC.
I'm using Windows 7 x64.
xbmc.log
13:46:02 T:4460  NOTICE: -----------------------------------------------------------------------
13:46:02 T:4460  NOTICE: Starting XBMC (11.0 Git:20120321-14feb09), Platform: Windows 7, 64-bit (WoW) Service Pack 1 build 7601. Built on Mar 21 2012 (compiler 1600)
13:46:02 T:4460  NOTICE: Intel(R) Core(TM) i5-2410M CPU @ 2.30GHz
13:46:02 T:4460  NOTICE: Desktop Resolution: 1366x768 32Bit at 60Hz
13:46:02 T:4460  NOTICE: Running with administrator rights
13:46:02 T:4460  NOTICE: Aero is enabled
13:46:02 T:4460  NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
13:46:02 T:4460  NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
13:46:02 T:4460  NOTICE: special://masterprofile/ is mapped to: C:\Users\NeoCorps\AppData\Roaming\XBMC\userdata
13:46:02 T:4460  NOTICE: special://home/ is mapped to: C:\Users\NeoCorps\AppData\Roaming\XBMC\
13:46:02 T:4460  NOTICE: special://temp/ is mapped to: C:\Users\NeoCorps\AppData\Roaming\XBMC\cache
13:46:02 T:4460  NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
13:46:02 T:4460  NOTICE: Local hostname: NeoCorps-Lap
13:46:02 T:4460  NOTICE: Log File is located: C:\Users\NeoCorps\AppData\Roaming\XBMC\xbmc.log
13:46:02 T:4460  NOTICE: Setup SDL
13:46:02 T:4460  NOTICE: Found screen: Generic PnP Monitor on Intel(R) HD Graphics Family, adapter 0.
13:46:02 T:4460  NOTICE: Primary mode: 1366x768 @ 60.00 - Full Screen
13:46:02 T:4460  NOTICE: Additional mode: 320x200 @ 60.00 - Full Screen
13:46:02 T:4460  NOTICE: Previous line repeats 2 times.
13:46:02 T:4460  NOTICE: Additional mode: 320x240 @ 60.00 - Full Screen
13:46:02 T:4460  NOTICE: Additional mode: 400x300 @ 60.00 - Full Screen
13:46:02 T:4460  NOTICE: Additional mode: 512x384 @ 60.00 - Full Screen
13:46:02 T:4460  NOTICE: Additional mode: 640x400 @ 60.00 - Full Screen
13:46:02 T:4460  NOTICE: Additional mode: 640x480 @ 60.00 - Full Screen
13:46:02 T:4460  NOTICE: Additional mode: 800x600 @ 60.00 - Full Screen
13:46:02 T:4460  NOTICE: Additional mode: 1024x768 @ 60.00 - Full Screen
13:46:02 T:4460  NOTICE: Additional mode: 1280x600 @ 60.00 - Full Screen
13:46:02 T:4460  NOTICE: Additional mode: 1280x720 @ 60.00 - Full Screen
13:46:02 T:4460  NOTICE: Additional mode: 1280x768 @ 60.00 - Full Screen
13:46:02 T:4460  NOTICE: Additional mode: 1360x768 @ 60.00 - Full Screen
13:46:02 T:4460  NOTICE: Additional mode: 1366x768 @ 60.00 - Full Screen
13:46:02 T:4460  NOTICE: load settings...
13:46:02 T:4460  NOTICE: special://profile/ is mapped to: special://masterprofile/
13:46:02 T:4460  NOTICE: loading special://masterprofile/guisettings.xml
13:46:02 T:4460  NOTICE: Getting hardware information now...
13:46:02 T:4460  NOTICE: Checking resolution 12
13:46:02 T:4460  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
13:46:02 T:4460  NOTICE: Loaded playercorefactory configuration
13:46:02 T:4460  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
13:46:02 T:4460  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
13:46:02 T:4460  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
13:46:02 T:4460  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
13:46:02 T:4460  NOTICE: Default DVD Player: dvdplayer
13:46:02 T:4460  NOTICE: Default Video Player: dvdplayer
13:46:02 T:4460  NOTICE: Default Audio Player: paplayer
13:46:02 T:4460  NOTICE: Disabled debug logging due to GUI setting. Level 0.
13:46:02 T:4460  NOTICE: Log level changed to 0
13:46:02 T:4460  NOTICE: Loading media sources from special://masterprofile/sources.xml
13:46:03 T:3516   ERROR: CRemoteControl::Connect - failed to connect
That's all it does as for the log for current session. Anything else I should look for?
The point it's stopping at is where a graphics related crash often happens. I note it's an Intel GPU, and we all love Intel graphics processors. It would be worth checking the video drivers are the latest version.
If you can't kill a process this almost always means the process has hung in a call into a device driver. This is the only circumstance in which Windows cannot terminate a process (because doing so would leave the kernel in an indeterminate state).
Is it possible to change the graphic driver Xbmc uses?, I have a dedicated Nvidia Graphic card and that Intel Graphics card too.
I've the same problem
Go to nvida control panel 3d settings/Manage 3D settings under Global settings choose High-performance NVIDA Processor.
Save settings close nvida cpanel.
start xbmc - now it should run on nvida not intel
