2012-05-08, 22:26
I tried out the metropolis skin today and it just makes xbmc go black. I can hear the clicking that occurs when going through the menus and what not but I can't see anything to switch skins again, any help please?
(2012-05-03, 20:23)crawl Wrote: [ -> ]If you don't want to lose some of your current settings, then transfer the guisettings.xml file to your desktop, open it in an editor, and look for the "lookandfeel" section:
Quote: <lookandfeel>
<enablerssfeeds>true</enablerssfeeds>
<font>Default</font>
<rssedit></rssedit>
<skin>skin.confluence</skin>
<skincolors>SKINDEFAULT</skincolors>
<skintheme>SKINDEFAULT</skintheme>
<skinzoom>0</skinzoom>
<soundskin>SKINDEFAULT</soundskin>
<startupwindow>10000</startupwindow>
</lookandfeel>
Change it to match the above.
(2012-05-08, 22:34)hernandito Wrote: [ -> ]Which version of XBMC are you using... Mac, Win, XBMCbuntu? You will need to go to the addons folder, delete the folder with the new skin and restart XBMC... It should go back to Confluence.
(2012-05-08, 23:29)jonass21 Wrote: [ -> ]i don't know if it changes things because im on linux but i go to usr/share/xbmc/usrdata and there is no guisettings.xml file even when logged in as root
(2012-05-09, 00:58)dnairb Wrote: [ -> ](2012-05-08, 23:29)jonass21 Wrote: [ -> ]i don't know if it changes things because im on linux but i go to usr/share/xbmc/usrdata and there is no guisettings.xml file even when logged in as root
Your downloaded addons, guisettings.xml, etc. are found in the $HOME/.xbmc/userdata/ folder on Linux systems
(2012-05-09, 02:15)jonass21 Wrote: [ -> ]It will be under home. Do you see any folders that start with . ? If not, then do ctrl+H so it shows your hidden files.(2012-05-09, 00:58)dnairb Wrote: [ -> ](2012-05-08, 23:29)jonass21 Wrote: [ -> ]i don't know if it changes things because im on linux but i go to usr/share/xbmc/usrdata and there is no guisettings.xml file even when logged in as root
just when i think im getting the hang of linux.... I don't see .xbmc folder in my home directory, or my /root directory so I guess $home must be something different... could you help me to access it? I'm linux mint 11
(2012-05-09, 03:40)Aenima99x Wrote: [ -> ]Not sure if you have a reason for staying on Dharma (10.1), but if you upgrade to Eden (11), then you'll be able to use Metropolis.
