2012-05-09, 13:51
Hey! So I've got a problem with some video files I'm trying to watch!
They are all MP4 files. XBMC can scrape the files fine, but shows no info about the video resolution/codec. They do show the audio codec. Upon playing I get a blank black screen with the audio playing fine in the background.
All files play fine with VLC.
Other MP4 files play fine in XBMC.
I think it could be something with the files themselves...but I'm not sure how to go about fixing them! Any suggestions?
Here is the mediainfo for one of the affected files:
General
Complete name : XXXX (removed)
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 546 MiB
Duration : 55mn 22s
Overall bit rate mode : Variable
Overall bit rate : 1 378 Kbps
Movie name : (removed)
Performer : (removed)
Genre : TV Shows
Recorded date : 2008-08-11
Encoded date : UTC 2008-08-14 02:09:14
Tagged date : UTC 2008-08-14 03:07:29
Comment : (removed)
stik : 10
tvsh : (removed)
tven : (removed)
tvnn : (removed)
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L3
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : 20
Duration : 55mn 22s
Source duration : 55mn 22s
Bit rate mode : Constant
Bit rate : 1 243 Kbps
Nominal bit rate : 1 330 Kbps
Width : 640 pixels
Height : 360 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.180
Stream size : 493 MiB (90%)
Source stream size : 493 MiB (90%)
Language : English
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 55mn 22s
Bit rate : 128 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 KHz
Stream size : 49.6 MiB (9%)
Source stream size : 49.6 MiB (9%)
Language : English
Encoded date : UTC 2008-08-14 02:09:15
Text #2
Format : Apple text
Codec ID : text
Duration : 55mn 22s
Bit rate mode : Variable
Language : English
Encoded date : UTC 2008-08-14 03:07:29
General
Format : MPEG-4
Codec ID : mp42
File size : 546 MiB
Duration : 55mn 22s
Genre : TV Shows
Comment : (removed)
stik : 10
tvsh : (removed)
tven : (removed)
tvnn : (removed)
Video
Codec ID : 20
Duration : 55mn 22s
Width : 640 pixels
Height : 360 pixels
Color space : YUV
Bit depth : 8 bits
Language : English
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 55mn 22s
Bit rate : 128 Kbps
Language : English
Text #2
Format : Apple text
Codec ID : text
Duration : 55mn 22s
Language : English
