Full Version: [SOLVED] 30fps shows way too bright. other are fine
Since putting on Eden, I've noticed that my 30fps shows are far too bright, while the rest (24, 25, 29, 60fps) show just fine.
Oddly, when i set my Windows refresh to 30hz, it looks fine, but 60hz has the same 'too bright' brightness.. Very odd. I have both 'Adjust display refresh to display' and 'Sync playback to display' options selected in XBMC, as this has always been what gives me the best resutls.
Is there a settings in XBMC files somewhere that will allow me to change brightness for only a single refreshrate/resolution combo?
Oops, forgot specs:
Eden 11.0
Win 7 x64
HD6770 Running 12.3 drivers.
HDMI runnign to Yahama receiver, then to HDMI to LG 55LE5300
Okay i sorted it out. For some reason, that res/hz combo was teh only one to revert back to RGB Limited instead of full..
