Full Version: Need help capturing video...
Not had much luck getting FRAPS to work on my system, anyone know of any other software I can try to capture some video of my XBMC setup in action?
Also, anyone know of any software I can use to join some mp4 files I have? Would have posted this in Off-Topic but I do not have the permissions on my account.
Running Eden on Vista.
Merge MKV should be able to join mp4 files, drag & drop.. use the append function. No idea of what video capture software to use...
(2012-05-14, 16:18)PatK Wrote: [ -> ]Merge MKV should be able to join mp4 files, drag & drop.. use the append function. No idea of what video capture software to use...
Thanks for your help Pat, I'll give it a go. Repworthy. Smile
