Full Version: installed openelec on 2gb microsd card, what happens when it fills up?
what happens when my .'..userdata/thumbnails' folder fills up the flash drive? will it spill over elsewhere, or can i somehow change the path of the userdata folder onto my media storage drive, where space is not an issue?
thank you in advance!
Yes you can. Assuming both are mounted:
# turn off XBMC before doing this
$ mv /home/xbmc/.xbmc /mediaStorageMount/
# make a link to the folder
$ ln -s /home/xbmc/.xbmc /mediaStorageMount/.xbmc
Replace "mediaStorageMount" with the path to the mount point for the media storage drive.
