Full Version: XBMC repository update doesn´t work
Hi Everyone!, well this is my first post, do get mad with me, since I searched the whole site, FAQ´s and the web.
I have a W7 x64, 4GB, GA-E350N mobo...
The XBMC version I have is the Eden 11
So I looked for a grooveshark add on and I found that on the wiki there are two groovesharks, the script and another one...I downloaded XMBC grooveshark and even though I 100% sure I entered my user and password correctly I keep getting "unable to login" I searched and I discovered that a plugin needs to be updated...I tried to find it on my repository and I couldn´t do it.
So I went to my add ons on my setup and I see
"XBMC.org Add-ons" Version 2.0.3-
I tried to "check for updates" and "force refresh" and nothing happens...
So I think I have and old repository...
Is there any new version? I got the wrong one? Can I update it via zip file? I uploaded the Log file...
Thanks and my apologies if my questions are repeated ...
Big Grin
You have to differ between XBMC version and Add-ons repository version Wink
So, I have the right version of the repository? Big Grin
Thx!
