On rare occasions there are shows that I'm watching that just abruptly stop before their end time.
At first I thought they were bad downloads, however when playing them in VLC, they play all the way thorugh.
Not sure what is causing this to occur.
I have tested this on 2 different PC's running XMBC (same version) one of them being a VM.
The show it is occurring on this time is Ax Men 5x16
XBMC: 11.0 (Compiled March 21 2012)
http://pastebin.com/f3RCCTeK
Try them using a ffmpeg based player such as mplayer and see if they exhibit the same behavior. XBMC's player is based of ffmpeg.
Taking a quick look at the log it appears there are read errors with the file:
06:37:30 T:2976 ERROR: ffmpeg[BA0]: [matroska,webm] Read error at pos. 1032687370 (0x3d8d8f0a)
06:37:31 T:2976 ERROR: ffmpeg[BA0]: [matroska,webm] Read error at pos. 1032687371 (0x3d8d8f0b)
06:37:38 T:2564 DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_EOF
06:37:38 T:2564 DEBUG: CDVDAudio::Drain - adding 21024 bytes of silence, buffer size: 16128, chunk size: 37152
06:37:38 T:2564 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
06:37:39 T:1404 ERROR: ffmpeg[57C]: [h264] error while decoding MB 52 40, bytestream (4294967281)
06:37:39 T:1404 INFO: ffmpeg[57C]: [h264] concealing 397 DC, 397 AC, 397 MV errors
(2012-05-14, 16:50)kricker Wrote: [ -> ]Try them using a ffmpeg based player such as mplayer and see if they exhibit the same behavior. XBMC's player is based of ffmpeg.
Tried playing it with smplayer and it stops at the same point.
I could re-download the episode, but is it really bad if VLC plays it all the way through?
I figured it would. I've seen this issue before. I'm not sure ffmpeg based players quit on the file while other do not. That is for the devs to figure out.
Can you tell me at what time your Ax Men file quits playing?
Dealing with the same issue, lots of different files, generally all HD but some SD stuff as well. Here's a debug log of one:
http://pastebin.com/B9w029jA
Interesting snippet:
22:03:10 T:4496 INFO: ffmpeg[1190]: [matroska,webm] Unknown entry 0x496E
22:03:10 T:4496 INFO: ffmpeg[1190]: [matroska,webm] Unknown entry 0xEE
22:03:11 T:4496 INFO: ffmpeg[1190]: [matroska,webm] Unknown entry 0x4C9A
22:03:11 T:4496 INFO: ffmpeg[1190]: [matroska,webm] Unknown entry 0x17B39D19
22:03:11 T:4496 INFO: ffmpeg[1190]: [matroska,webm] Unknown entry 0xF6
22:03:11 T:4496 INFO: ffmpeg[1190]: [matroska,webm] Unknown entry 0x8C
22:03:11 T:4496 INFO: ffmpeg[1190]: [matroska,webm] Unknown entry 0xC7
22:03:11 T:4496 INFO: ffmpeg[1190]: [matroska,webm] Unknown entry 0x47C7
22:03:11 T:4496 INFO: ffmpeg[1190]: [matroska,webm] Unknown entry 0x1AF6D911
22:03:11 T:4496 INFO: ffmpeg[1190]: [matroska,webm] Unknown entry 0xBE
22:03:11 T:4496 INFO: ffmpeg[1190]: [matroska,webm] Unknown entry 0x7D31
22:03:11 T:4496 INFO: ffmpeg[1190]: [matroska,webm] Unknown entry 0xF9
22:03:11 T:4496 INFO: ffmpeg[1190]: [matroska,webm] Unknown entry 0x458B
22:03:15 T:5028 DEBUG: CDVDPlayerAudio:: Discontinuity - was:1212519326.598540, should be:1212529438.772165, error:10112.173625
22:03:18 T:5028 DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_EOF
22:03:18 T:5028 DEBUG: CDVDAudio::Drain - adding 1824 bytes of silence, buffer size: 35328, chunk size: 37152
22:03:18 T:5028 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
22:03:19 T:4660 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
22:03:19 T:4496 INFO: CDVDPlayer::Process - eof reading from demuxer
22:03:19 T:4496 NOTICE: CDVDPlayer::OnExit()
22:03:19 T:4496 NOTICE: DVDPlayer: eof, waiting for queues to empty
... boring video shutdown messages follow.
The same file plays correctly on mplayer (using ffmpeg's libavcodec "0.6.1+svn20101128") so I'm not sure what's going on. vlc plays the file correctly on the same computer via the network share, so I don't think it's a network problem either.
How do I find out what ffmpeg version xbmc 11 is using on my system?
[BUMP] Did you ever figure this one out? I'm experiencing this more and more here too, on my Intel DN2820FYKH. Running Gotham Beta4.
