My smart playlist doesn't work, (EDEN 11, mac mini) when i make a list that will find DTS movies it only find a few of them, not evrey one as it should.
and when im inside FILES and then the movie map, it wont show me the dts info down of the about the movie info codecs. just "?" "?" "?" "?".
and i have done update on the files libary. i think :S
XBMC probably extracted the stream details yet, for iso images I believe you still have to open them and start playing them back.
But its not iso files, mkv an other files.
I cant get my smart list with dts movies to work, it just find some of my dts movies.... here is a debug file if thats helps,
Eden 11
Mac minu 10.7.4
http://tinypaste.com/60392221
Have you tried to start and stop any of the affected movies?
yes and they work! they just wont show up in my playlist, no one of the new added....
As far as I can tell you didn't actually click on your smartplaylist at all in that run.
do they show any codec info after starting and stopping?
If XBMC has no idea of the properties of the files, there is no wonder it cannot filter them according to your smart playlist.
Still same problem, to get the movies to my own playlist, i have to go to my files and go into the movie map and then it will show up in my own playlist with just dts movies for exampel...
http://tinypaste.com/e41d1742
and should i scan with "Movies are in separate folders that match the movies"? what does it mean
i have a movie like HARDDRIVE -> MOVIES - > Gladiator2002.a,as.d. - > Gladiator.mkv
this one then?
To get the movies to my own playlist, i have to go to my files and go into the movie map and then it will show up in my own playlist with just dts movies for exampel...
i have a movie in like HARDDRIVE -> MOVIES - > Gladiator2002.a,as.d. - > Gladiator.mkv
I can't get my smart playlist to work, where i have dts movies, dolby digital movies, HD movies with 720p 1080p resulution.
when i put my new movies on the harddrive where the other movies are, the new ones wont show up on my own playlists
i put a log down here if it helps to help me out.
and one more thing
i have the movies in like HARDDRIVE -> MOVIES - > Gladiator2002.a,as.d. - > Gladiator.mkv
should i scan with "Movies are in separate folders that match the movies"? or what does it mean?
Don't create another thread with the same question (which i deleted)!
