Full Version: help multiple movie TVshow sources.
Some of my movies I either have more than one quality movie and/or multiple sources. Same with TV Shows.
My problem is in my library it shows the movie in the list more than once same with tv episodes.
Is there a setting or addon that will group movies and tv show episodes with the same name as a folder.
Example...
Instead of the following in my list of movies...
Toy Story 720p
Toy Story 1080p
It will show...
Toy Story
and when selected a popup window with the following...
Toy Story 720p
Toy Story 1080p
and the same with TV Shows.
Thanks in advanced.
Rick
You could try smart playlists and add different rules to them including a quality/resolution rule.
XBMC doesn't have support for multi-quality per item. If you have more than one instance of the item, you will see both of them listed. The tips listed above maybe your best option, but it will not really do as you want.
