Looking to build my first HTPC
Quick question - Are any of the recommended builds able to function OK heat wise if they are in an enclosed area? basically my TV stand has 2 cabinets underneath it with doors - Would any HTPC function OK in an enclosed area like this? Or would airflow be an issue?
Lots of tips here:
http://lifehacker.com/5619746/how-to-bui...ent-center
Your cabinet is essentially a case, so you need to create some airflow. Shouldn't be as tough as how Lifehacker did it, but that gives you a clue. Unless you are putting it in a case and then the case inside the cabinet. Then you probably still need somewhere for air to escape the cabinet.
I would think that as long as mentioned above, the cabinet isn't a completely sealed unit, it should be fine provided you have a well ventilated case with decent airflow passing through it.
I don't see why not.
There is already a hole in the back. Maybe you can put a little fan there?
I would most certainly put a fan in there.. may even make the hole larger and place a 200mm in. One other thign to be wary of is vibration. I had a fridn do something similar and a little hum from his drives ended up being reverberated throughout the cabinet, adn was actually pretty lound. Fortunately, there are many ways to keep it quite.
