Full Version: Audio CD playback issue
I seem unable to play Audio CD's on my XBMC install (11.0 stable build)
On inserting a disk, or clicking play disk in the menu, the player rapidly flicks thru each track, without playing them, then stops.
I've attached a debug log, this output is repeated for every track.:
11:08:20 T:11372032   DEBUG: CPlayerCoreFactory::GetPlayers(cdda://local/13.cdda)
11:08:20 T:11372032   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
11:08:20 T:11372032   DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
11:08:20 T:11372032   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv
11:08:20 T:11372032   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/rtmp/mms/udp
11:08:20 T:11372032   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
11:08:20 T:11372032   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
11:08:20 T:11372032   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
11:08:20 T:11372032   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
11:08:20 T:11372032   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdfile
11:08:20 T:11372032   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
11:08:20 T:11372032   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
11:08:20 T:11372032   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
11:08:20 T:11372032   DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
11:08:20 T:11372032   DEBUG: CPlayerCoreFactory::GetPlayers: adding audiodefaultplayer (3)
11:08:20 T:11372032   DEBUG: CPlayerCoreFactory::GetPlayers: for video=0, audio=1
11:08:20 T:11372032   DEBUG: CPlayerCoreFactory::GetPlayers: adding player: PAPlayer (3)
11:08:20 T:11372032   DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
11:08:20 T:11372032   DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
11:08:20 T:11372032   DEBUG: CPlayerCoreFactory::GetPlayers: added 2 players
11:08:20 T:11372032   DEBUG: DllAvUtilBase: Using libavutil system library
11:08:20 T:11372032   DEBUG: DllAvCodec: Using libavcodec system library
11:08:20 T:11372032   DEBUG: DllAvFormat: Using libavformat system library
11:08:20 T:11372032   DEBUG: Open - not spdif or dts file, fallbacking
11:08:20 T:11372032   ERROR: Init: Error creating demuxer
11:08:20 T:11372032   DEBUG: CFileCache::Open - opening <13.cdda> using cache
11:08:20 T:11372032    INFO: PAPlayer: Playing cdda://local/13.cdda
11:08:20 T:11372032   DEBUG: PAPlayer: Using existing audio renderer
11:08:20 T:11372032   DEBUG: OnInitialize() started
11:08:20 T:11372032   DEBUG: Updating visualisation albumart:
11:08:20 T:11372032   DEBUG: OnInitialize() done
11:08:20 T:2702154560   DEBUG: Thread PAPlayer start, auto delete: 0
11:08:20 T:2702154560   DEBUG: PAPlayer: Thread started
11:08:20 T:2710547264   DEBUG: Thread XFILE::CFileCache start, auto delete: 0
11:08:20 T:2710547264   ERROR: file cdda: Reading 52 sectors of audio data starting at lsn 232257 failed with error code -1
11:08:20 T:2710547264    INFO: CFileCache::Process - Hit eof.
11:08:20 T:11372032   DEBUG: CGUIInfoManager::SetCurrentSong(cdda://local/13.cdda)
11:08:20 T:11372032   DEBUG: LoadMusicTag: loading tag information for file: cdda://local/13.cdda
11:08:20 T:11372032   DEBUG: Xcddb::queryCDinfo discid [0512b911] already cached
11:08:20 T:11372032   DEBUG: Loading additional tag info for file cdda://local/13.cdda
11:08:20 T:11372032   DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
11:08:20 T:11372032   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
11:08:20 T:2702154560   ERROR: CAudioDecoder: Error while decoding 1
11:08:20 T:2710547264   DEBUG: Thread XFILE::CFileCache 2710547264 terminating
11:08:20 T:2702154560    INFO: PAPlayer: End of playback reached
11:08:20 T:2702154560   DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
11:08:20 T:2702154560   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
11:08:20 T:2702154560   DEBUG: PAPlayer: Thread end
11:08:20 T:2702154560   DEBUG: Thread PAPlayer 2702154560 terminating
Any ideas?
Are you using a USB optical drive?
