Full Version: XBMC failed to play 25fps mkv
I'm having troubles playing an MKV file with 25fps video on XBMC (blank screen with audio), while MPC-HC works fine on the same computer.
My computer:
- Windows 7 Ultimate SP1 64 bit.
- AMD Phemon II X4 960T 3.00 GHz
- 8GB RAM
- NVIDIA GeForce GTX 460 8.17.12.9610
XBMC Log:
Quote: http://pastebin.com/download.php?i=VZMuGngY
Video information from MPC-HC
Quote:General
Unique ID : 208291681383715918099523233218851365803 (0x9CB384C538CA3447A82D852F30BDE3AB)
Complete name : Life.Ep.01.Challenges.of.Life.BluRay.mkv
Format : Matroska
Format version : Version 2
File size : 12.2 GiB
Duration : 58mn 33s
Overall bit rate : 29.9 Mbps
Encoded date : UTC 2012-05-20 15:24:53
Writing application : mkvmerge v5.5.0 ('Healer') built on Apr 6 2012 21:43:24
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Video
Format : VC-1
Format profile : AP@L3
Codec ID : WVC1
Codec ID/Hint : Microsoft
Duration : 58mn 33s
Bit rate : 27.8 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.536
Stream size : 11.4 GiB (93%)
Language : English
Audio
Format : DTS
Format/Info : Digital Theater Systems
Muxing mode : Header stripping
Codec ID : A_DTS
Duration : 58mn 33s
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 632 MiB (5%)
Language : English
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English
Menu
00:00:00.000 : en:00:00:00.000
00:10:38.679 : en:00:10:38.679
00:17:09.480 : en:00:17:09.480
00:27:17.000 : en:00:27:17.000
00:40:28.279 : en:00:40:28.279
00:47:56.000 : en:00:47:56.000
I tried 'Adjust display refresh rate to match video' and 'Sync playback to display' but they did not help.
Is this a known issue and is going to be fixed?
Thanks very much.
This problem is not 25 fps . The problem is interlaced video VC-1 . On-board DVDPlayer can't play it , even new alphas 12 . Build with DSplayer can . Developers say is the fault of ffmpeg, but the problem was fixed in MPC-HC ,LAV and other based ffmpeg , long time ago ..
Thanks, I tried a DSplayer build, but it does not work either. Guess I'm stucked with MPC-HC as external player for those. Makes me feel unease with the on-board DVDPlayer a little bit, but well...
