(2012-09-02, 12:45)nemulate Wrote: [ -> ]reazorFX thank you for the music OSD in album view and all the other changes
A while ago I asked for an option to change the thumbnail in video files views to a video case layout rather than the current square cd case layout. Just wondered if you'd had a chance to look at this yet?
o shure ... lost in space.... my mistake.
Check!
(2012-09-02, 20:18)noiz13 Wrote: [ -> ]@ can you get the OSD out of the way when your using subtitle options choosing one or timing the subtitel time?
yeah sure thx!
Many thanks again Reazor, love your sure and steady approach to developing this skin and your willingness to listen to suggestions and implementing some of them.
It's a classy looking skin.
Hi reazorFX!
Congratulations for this excellent skin. I have a question for the Visualation OSD. Will change that in the near future?
Uploaded with
ImageShack.us
(2012-09-03, 16:01)Harlock1977 Wrote: [ -> ]Hi reazorFX!
Thx! Yes sure it's also on my ToDo list.
greetz
i use ember too. i it's usually recommended to remove min from ember settings. i had that issue ages ago when first using XBMC. thanks for adding it tho.
also notice that the "Pictures" option in settings doesn't have an image.
(2012-09-05, 19:12)Shinu Wrote: [ -> ]i use ember too. i it's usually recommended to remove min from ember settings. i had that issue ages ago when first using XBMC. thanks for adding it tho.
yea it´s a setting problem on ember.
Picture is just fixed. Thx bro.
I´m just working on the Recently Added. The View from Avallonis is not possible. I can´t get the Show Thumb ( LatestEpisode.[1-10].ShowThumb)... is not available maybe on Frodo.
I´ll will make this view.
also the Playlist-Editor and Media-Browser is reworked:
(2012-09-06, 00:01)noiz13 Wrote: [ -> ]love it
merci
In Process:
I could still display the fanart
(2012-09-07, 17:26)Shinu Wrote: [ -> ]looks really good. are u going to place "Season/Episode" anywhere for the recently added?
Season/Episode... sure.... and include
Little Preview:
The RecentlyAdded pop up when focus Movie, TH-Shows and Music.
-1-
-2- (pop up)
Hi folks,
Most have done. Recently Added are finished, Star Rating in Movies finished, hide OSD when Subtitle Slider, Scroll Text Recently Added Movie-Title and i will include a option to enable and disable separately the Album Recently Added, Movie Recently Added and TV Show Recently Added.
I have to do a few small things, then I upload the new version.
actually would be the banner view for tv shows, but...
I would like wait until Frodo released because the handling of banner and posters will be much easier
http://forum.xbmc.org/showthread.php?tid...ght=banner
In any case I want to make a new view next. What view .....let yourselves be surprised
