Full Version: [Solved] Problems with comitment
I really like my AN 2.0 set up and the WAF is high. However, I would like to run the new RC because perfection is a moving target. Is there an easy way to run both using the zip? It appears that you have to over write the existing install n'est pas?
Thanks for the outstanding skin.
Easiest would be to download it from here:
http://passion-xbmc.org/addons/?Page=Vie...on.nox.svn
That way its a new skin called Aeon Nox (GIT) you can keep next to your 2.0 install.
Settings wont be interchangeable when 3.0 hits the repo though.
Thanks. That works well.
