2012-05-21, 13:07
2012-05-21, 13:27
be more specific. which viewtypes are you talkin about?
2012-05-21, 14:27
I was just going to ask the same question. For me, using low list. Thanks.
2012-05-23, 22:17
Sorry, low list view being used in both movies and TV shows
2012-05-23, 22:20
not for 3.0.
post it on github issues pages if you want us to do that for post-3.0
2013-01-12, 03:34
Rather than creating a new thread..
I've just updated (been on holidays) I'm wondering how to show DVD cases in the Showcase view for TV Shows.. It doesn't look it is available but what are the chances it will come back ? and was there any reason why this switch was taken out ?
2013-01-12, 03:43
(2013-01-12, 03:34)Radar Wrote: [ -> ]Rather than creating a new thread..
because they donĀ“t make any sense for tvshows.
2013-01-12, 03:50
Well to some maybe, but for myself it looks the same as the movies and I quite like it.. I take it you won't be adding the switch that gives people choice ? if this is so, what code do I need to add to make this work ? (if you don't mind me adding it)..
2013-01-12, 04:38
(2013-01-12, 03:50)Radar Wrote: [ -> ]Well to some maybe, but for myself it looks the same as the movies and I quite like it.. I take it you won't be adding the switch that gives people choice ? if this is so, what code do I need to add to make this work ? (if you don't mind me adding it)..
correct. no option for that. code for that is in viewtype_showcasemovies.xml and variables.xml probably.
2013-01-12, 05:21
Thank you Phil, saves me looking through all the xml's.. added the button back in also and all works well..
I might be the only one but hey, I like it...
