Full Version: control shairport from xbmc?
is there a way to control shairport through xbmc when streaming music? thanks!
What do you mean? Are you running windows or why don't u use the internal airtunes support? Or i just didn't get that question right.
I installed shake port on windows to play mp3s to my xbmc.
I was wondering if i could control the music from AirPlay using xbmc?
Also does AirPlay use up a lot of memory for xbmc? Xbmc becomes sluggish for me on 12 alpha with airplay enabled
