Full Version: Connect to external Airplay Server?
Hi, I am wondering if I can use XBMC on my Windows PC to connect to an external Airplay server. I am trying to bypass using Air Playit on my ipod touch.
If so can you tell me where I would put in the server ip address, port and login info? I read a little about the advancesettings.xml file but I am not sure if this is the right place. Is it even possible to setup an Airplay server on another network?
Thank you!
Not supported.
Bummer. Do you know of any program that will do this? Thanks.
