Full Version: Updated to nightlies but no options for HD Audio
Pages: 1 2
Hi guys
Ive updated to nightlies using
ppa:team-xbmc-svn/ppa
expecting to see options for HD audio, but i dont.
I see the new services menu, but no options for HD audio like i do in the windows nightlies.
System is saying XBMC 12.0-Alpha1 Git:unknown ( compiled : apr 20 1012 )
Any ideas?
Matt
also dont seem to have the new default skin
Matt
nobody?
Matt
audio engine was merged on may 10th... your build is to old for having these options...
thats what i thought, when i do update it says its the latest version.
im doing
sudo apt-get update
sudo apt-get install xbmc
it just says it the latest version and wont update
Matt
that's the problem with 'latest', it could mean anything and nothing at the same time.
this is what im following
http://shadower16.wordpress.com/2011/10/...nightlies/
just formatted and did a clean install of xbmc live 10.1 ( i think, the one before it was called xbmcbuntu ) followed the instructions and still ended up on the same build.
Matt
You are not pulling a nightly version but a alpha version.
They are in different locations (if available for ppa)
Matt, I am in the same boat, looking for a way to update to the master eden branch (for someone like me that isn't afraid to follow instructions but not a linux guru).
I haven't had any luck with instructions on compiling or installing that I found in the wiki or forum. I completely understand, for one they are test versions probably not really for us, more standard users. Also I know I wouldn't be too excited in the tedious and thankless task of writing guides.
Hopefully with the change to monthly test cycles known Dharma processes will be updated/communicated for eden. For the time being, I think I have pretty much given up, going to go back to Dharma or Openelec Dharma.
I know openelec has a thread with some Audio Engine builds that people compiled and put up, but I didn't have luck with those (at least for HD audio passthrough). Though it did look promising, menu sounds worked without a problem (always had had to do some sort of editing to get that to work).
EDIT: Thanks John... or nathan lol
Testing now, though my system has been knocked around a bit with various attempts and compile etc.
EDIT 2: Not working on XBMCbuntu, re-installed 11.0 from iso... At boot login, prompt, got into xbmcbuntu, and xbmc just wouldn't open. I assume because the PPA is more geared towards full linux installs. Well it was worth a try, Matt it may work for you.
(2012-05-22, 02:12)dandirk Wrote: [ -> ]EDIT 2: Not working on XBMCbuntu, re-installed 11.0 from iso... At boot login, prompt, got into xbmcbuntu, and xbmc just wouldn't open. I assume because the PPA is more geared towards full linux installs.
XBMCbuntu ist a full Ubuntu... what did you do to update?
I tried that following:
Install 11.0 from ISO (not sure if this maters, but entered xbmc and a password when prompted during install.
From putty ssh...
sudo add-apt-repository ppa:nathan-renniewaldock/xbmc-nightly
sudo apt-get update
that's the same as me but I'm coming from 10.1 (dahma)
Matt
Found the crash log
################ SYSTEM INFO ################
Date: Tue May 22 06:52:38 CDT 2012
XBMC Options:
Arch: i686
Kernel: Linux 3.0.0-19-generic-pae #33-Ubuntu SMP Thu Apr 19 20:59:10 UTC 2012
Release:
    Distributor ID:     Ubuntu
    Description:        Ubuntu 11.10 - XBMCbuntu
    Release:    11.10
    Codename:   oneiric
############## END SYSTEM INFO ##############
############### STACK TRACE #################
gdb not installed, can't get stack trace.
############# END STACK TRACE ###############
################# LOG FILE ##################
06:52:37 T:3018381072  NOTICE: -----------------------------------------------------------------------
06:52:37 T:3018381072  NOTICE: Starting XBMC (12.0-ALPHA2 Git:Unknown), Platform: Linux (Ubuntu 11.10 - XBMCbuntu, 3.0.0-19-generic-pae i686). Built on May 21 2012
06:52:37 T:3018381072  NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
06:52:37 T:3018381072  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
06:52:37 T:3018381072  NOTICE: special://masterprofile/ is mapped to: /home/xbmc/.xbmc/userdata
06:52:37 T:3018381072  NOTICE: special://home/ is mapped to: /home/xbmc/.xbmc
06:52:37 T:3018381072  NOTICE: special://temp/ is mapped to: /home/xbmc/.xbmc/temp
06:52:37 T:3018381072  NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
06:52:37 T:3018381072  NOTICE: Local hostname: xbmc
06:52:37 T:3018381072  NOTICE: Log File is located: /home/xbmc/.xbmc/temp/xbmc.log
06:52:37 T:3018381072  NOTICE: Setup SDL
06:52:38 T:3018381072  NOTICE: load settings...
06:52:38 T:3018381072  NOTICE: special://profile/ is mapped to: special://masterprofile/
06:52:38 T:3018381072  NOTICE: loading special://masterprofile/guisettings.xml
06:52:38 T:3018381072  NOTICE: Getting hardware information now...
06:52:38 T:3018381072  NOTICE: Checking resolution 12
06:52:38 T:3018381072  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
06:52:38 T:3018381072  NOTICE: Loaded playercorefactory configuration
06:52:38 T:3018381072  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
06:52:38 T:3018381072  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
06:52:38 T:3018381072  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
06:52:38 T:3018381072  NOTICE: Loaded settings file from special://profile/advancedsettings.xml
06:52:38 T:3018381072  NOTICE: Contents of special://profile/advancedsettings.xml are...
                                            <advancedsettings>
                                              <useddsfanart>true</useddsfanart>
                                              <cputempcommand>cputemp</cputempcommand>
                                              <gputempcommand>gputemp</gputempcommand>
                                              <samba>
                                                <clienttimeout>30</clienttimeout>
                                              </samba>
                                              <network>
                                                <disableipv6>true</disableipv6>
                                              </network>
                                            </advancedsettings>
06:52:38 T:3018381072  NOTICE: Default DVD Player: dvdplayer
06:52:38 T:3018381072  NOTICE: Default Video Player: dvdplayer
06:52:38 T:3018381072  NOTICE: Default Audio Player: paplayer
06:52:38 T:3018381072  NOTICE: Disabled debug logging due to GUI setting. Level 0.
06:52:38 T:3018381072  NOTICE: Log level changed to 0
06:52:38 T:3018381072  NOTICE: Loading media sources from special://masterprofile/sources.xml
06:52:38 T:3018381072   ERROR: PulseAudio: Failed to connect context
06:52:38 T:3018381072   FATAL: CApplication::Create: Failed to start the AudioEngine
############### END LOG FILE ################
Looks like pulse and AE have issues... thought pulse was not supposed to be usedHuh
oh well nature of the nightly beast lol
Try to move your guisettings.xml away and see if it starts up then. No clue why it trys pulseaudio - but imho in the latest code it should be supported.
Pages: 1 2
