Full Version: Ember Artwork ?
Hi All,
I have just scraped all my movies and tv shows with Ember. When i import my files into XBMC its not using the information or artwork from Ember. Its using XBMC's scraped information and artwork.
How do i make XBMC use the Ember info and art ?
Huh
It's almost always due to you not setting "Movies in separate folders not named after the movie" when in fact that's exactly how you have your media.
If this is not the case, detail exactly how you have your movies laid out and the exact settings you're using to scrape.
I have my media setup like this,
example...
E:\Movies\Pulp Fiction\Pulp Fiction.mkv
E:\TV Shows\Breaking Bad\Season 1\Breaking Bad s01e01.mkv
I have tried disabling scrapers, enabling scrapers and not setting media type etc... Just can't work it out
1. Set Content to "Movies" on E:\Movies.
2. Ensure that "Movies in separate folders named like the movie" is enabled.
3. Scan.
That's it. If it doesn't work, grab a Debug Log.
My media wasnt organised as good as i originally thought. ill re-organise and try again.
Is this the correct naming convention for TV shows ?
That method works great for me. If you have a lot of renaming to do I recommend a program called "filebot". Can rename and sort your files too.
(2012-05-24, 01:41)mbj1983 Wrote: [ -> ]Is this the correct naming convention for TV shows ?
Thanks ill look at "Filebot" Looks like its similar to "The Renamer"
