Full Version: XBMC suddently doesn't start anymore
All of a sudden XBMC will no longer launch for me. It just hangs on the XBMC Eden loading screen for ever.
Here's my log:
09:37:26 T:3040  NOTICE: -----------------------------------------------------------------------
09:37:26 T:3040  NOTICE: Starting XBMC (11.0 Git:20120321-14feb09), Platform: Windows 7, 64-bit (WoW) Service Pack 1 build 7601. Built on Mar 21 2012 (compiler 1600)
09:37:26 T:3040  NOTICE: Intel(R) Core(TM) i7 CPU         920  @ 2.67GHz
09:37:26 T:3040  NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
09:37:26 T:3040  NOTICE: Running with restricted rights
09:37:26 T:3040  NOTICE: Aero is enabled
09:37:26 T:3040  NOTICE: Setup SDL
09:37:26 T:3040  NOTICE: Found screen: Generic PnP Monitor on AMD Radeon HD 6800 Series, adapter 0.
09:37:26 T:3040  NOTICE: Found screen: Generic PnP Monitor on AMD Radeon HD 6800 Series, adapter 1.
09:37:26 T:3040  NOTICE: Primary mode: 1920x1080 @ 60.00 - Full Screen
09:37:26 T:3040  NOTICE: Secondary mode: 1024x768 @ 60.00 - Full Screen #2
09:37:26 T:3040  NOTICE: Additional mode: 640x480 @ 50.00 - Full Screen
09:37:26 T:3040  NOTICE: Previous line repeats 2 times.
09:37:26 T:3040  NOTICE: Additional mode: 640x480 @ 60.00 - Full Screen
09:37:26 T:3040  NOTICE: Additional mode: 640x480 @ 59.94 - Full Screen
09:37:26 T:3040  NOTICE: Additional mode: 720x480 @ 50.00 - Full Screen
09:37:26 T:3040  NOTICE: Additional mode: 720x480 @ 60.00 - Full Screen
09:37:26 T:3040  NOTICE: load settings...
09:37:26 T:3040  NOTICE: special://profile/ is mapped to: special://masterprofile/
09:37:26 T:3040  NOTICE: loading special://masterprofile/guisettings.xml
09:37:26 T:3040  NOTICE: Getting hardware information now...
09:37:26 T:3040  NOTICE: Checking resolution 11
09:37:26 T:3040  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
09:37:26 T:3040  NOTICE: Loaded playercorefactory configuration
09:37:26 T:3040  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
09:37:26 T:3040  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
09:37:26 T:3040  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
09:37:26 T:3040  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
09:37:26 T:3040  NOTICE: Default DVD Player: dvdplayer
09:37:26 T:3040  NOTICE: Default Video Player: dvdplayer
09:37:26 T:3040  NOTICE: Default Audio Player: paplayer
09:37:26 T:3040  NOTICE: Disabled debug logging due to GUI setting. Level 0.
09:37:26 T:3040  NOTICE: Log level changed to 0
09:37:26 T:3040  NOTICE: Loading media sources from special://masterprofile/sources.xml
09:37:27 T:3040  NOTICE: Enabled Joystick: Microsoft PC-joystick driver
09:37:27 T:3040  NOTICE: Details: Total Axis: 5 Total Hats: 1 Total Buttons: 23
09:37:27 T:3040  NOTICE: Details: Total Axis: 6 Total Hats: 1 Total Buttons: 20
09:37:29 T:3244   ERROR: CRemoteControl::Connect - failed to connect
That's the point XBMC hangs or crashes when there's a video problem. Have you updated the video drivers recently?
