So, it's all not fun in Apple TV land right now.
I've got a friends ATV2 I'm jailbreaking which keeps spitting error 1600. Blah, whatever, I'll fix it of f*#k it soon enough.
But in the process of messing with his, I had to unplug mine. Mine is running 4.4.4 (5.0.1) and has been running fine. After plugging mine back in it won't boot up. The AppleTV process just keeps restarting and dying, along with a ReportCras process. (I can still SSH in to TOP).
I can't find the shsh blobs for this device, so can anyone think of a way of fixing this without re-jailbreaking?
Any ideas welcome.....
Crash Report
Syslog [caution 109MB] Caution - 109MB file!!!
I had a similar problem, and also didn't have the shsh blobs saved for that appletv. Unfortunately I was had already restored to 4.2.1 before discovering you can use iFaith to get the blobs from the jailbroken device and the use that binary to rejailbreak/restore the appletv. (You can't use sea0nsnow then), but either ifaith or some companion software from the same group can do the jailbreak then.
Thanks, this is actually the process I'm going through with the other ATV2 I have here. The one I'm getting the 1600 errors with. I'd rather not have to re-jailbreak mine, it's a lengthy process, and can only be done with a windows computer, which I have to borrow. It won't work with a VM install of windows.
By the way, the syslog has 44 minutes left to upload as of now, so don't try to grab it yet.
For anyone who has this issue. I Found the fix.
Leave ATV running. Go out. See good band, drink lots of beer. Check ATV next day.
All fixed!
Got to love those crazy fix it fairies.
Well, my atv now has the same problem. It was working fine, then I exited xbmc back to the apple menu and it's now stuck in a loop. Tried a soft and hard reboot to no avail.
It's sunday night so I can't go out and see a band and drink lots of beer, so I have no idea how to fix this.
Ok. A little further investigation reveals.
a) it only crashes if connected to the internet
b) syslog shows:
May 27 17:42:52 Downstairs AppleTV[164]: Appliance com.apple.frontrow.appliance.movies not loaded because it doesn't have any categories.
May 27 17:42:52 Downstairs AppleTV[164]: Appliance com.apple.frontrow.appliance.music not loaded because it doesn't have any categories.
May 27 17:42:52 Downstairs AppleTV[164]: Appliance com.apple.frontrow.appliance.tv not loaded because it doesn't have any categories.
May 27 17:42:52 Downstairs AppleTV[164]: +[<ATVSWUpdateCheckTask: 0x3ee0093c> _shouldPerformCheck]
May 27 17:42:53 Downstairs AppleTV[164]: PM: Set PM idle time to 15 seconds.
May 27 17:42:53 Downstairs AppleTV[164]: PM: Set PM assertion to hold off idle sleep.
May 27 17:42:53 Downstairs AppleTV[164]: PM: Set PM assertion to enable idle sleep.
May 27 17:42:53 Downstairs AppleTV[164]: Serial Number:XXXXXXXXXX
*** OS 9A406a, IR 01.29, iBoot 1219.43.32, SW 4.4.4 / 3330 ***
*** OS partition size/free:596443136/68067328 ***
*** data partition size/free:7372734464/5728108544 ***
*** AVF main repository size:5654747546 ***
*** AVF secondary repository size:209715200 ***
*** Current Date:5/27/12 5:42 PM ***
*** Time Zone:Australia/Melbourne (AEST) offset 36000 (set:1) ***
*** Activation State:1 ***
May 27 17:42:54 Downstairs AppleTV[164]: *** Terminating app due to uncaught exception 'NSInternalInconsistencyException', reason: '-[__NSCFDictionary setObject:forKey:]: mutating method sent to immutable object'
*** First throw call stack:
(0x345ce8bf 0x30a391e5 0x345ce7b9 0x345ce7db 0x3453b62b 0x336441dd 0x33491589 0x33490d61 0x21b6b3b 0x21af8fd 0x3352f2eb 0x3352f03b 0x3352e9cb 0x3635150f 0x3459a577 0x345260cf 0x3452d22b 0x36366757 0x345a2b03 0x345a22cf 0x345a1075 0x345244dd 0x345243a5 0x335f0c33 0x335efbb3 0x744ec)
May 27 17:42:54 Downstairs com.apple.frontrow[164]: terminate called throwing an exception
and then CrashReporter kicks in.
Mine did seem to play up again. I backed up all of my XBMC user data, just in case. Then I completely removed XBMC and dependencies. (apt-get autoclean).
Then a fresh install of XBMC, following the wiki step for step for good measure, and my ATV seems to be stable again. Worth a try.
To note, I only have XBMC installed, if you have any other installs via apt-get it could be worth a try on them too.
Followed your tut to the tee (I've already tried this method before) and I just keep getting error 1600. I'll try to get a different cable, but if that fails, I give up.....
Different cable, same 1600 error. On multiple computers. Bugger it, looks like 5.1.1 it is.....
So it looks like other people have had this problem, and there's a solution, but no-one knows exactly what causes it nor what fixes it.
ATV2 Keeps Rebooting after Update
(2012-05-28, 13:03)IT-King Wrote: [ -> ]Contact me on the XBMC IRC mate, i will assist you there k
http://webchat.freenode.net/
If that was for me, I can't right now. Got to sleep, up for work at 0430hrs. But maybe tomorrow. I'm on GMT +10 here.
Anyway, don't want to turn this into a jail breaking thread.
After looking through, my issue seems to be related to a dependency problem with Nito or XBMC. If you get stuck in a reboot loop, SSH in and remove either or both of those, then re-install and you should be fixed.
Good info for future.
