2012-05-26, 23:55
Retina works when current mainline code is compiled with xcode4 (and ios sdk 5.1) - no code changes required - but we might need to bump the buildbot or so ...
(2012-05-26, 23:55)Memphiz Wrote: [ -> ]Retina works when current mainline code is compiled with xcode4 (and ios sdk 5.1) - no code changes required - but we might need to bump the buildbot or so ...Thanks for confirming. Just built from git master on iOS5.1, that works great, I wished I could say perfectly.
(2012-05-27, 03:41)davilla Wrote: [ -> ]don't build debug builds for iOS, they run much too slow.I know, was just trying first with xcode project defaults, had to fix some compilation errors, and then tested a bit.
diff --git a/xbmc/osx/ios/XBMCController.mm b/xbmc/osx/ios/XBMCController.mm
index 269b1ec..e11dfcc 100644
--- a/xbmc/osx/ios/XBMCController.mm
+++ b/xbmc/osx/ios/XBMCController.mm
@@ -58,9 +58,10 @@ extern NSString* kBRScreenSaverDismissed;
-@interface XBMCController ()
-UIWindow *m_window;
-IOSEAGLView *m_glView;
+@interface XBMCController () {
+ UIWindow *m_window;
+ IOSEAGLView *m_glView;
@end
@interface UIApplication (extended)
@@ -159,7 +160,7 @@ IOSEAGLView *m_glView;
[doubleFingerSingleTap release];
//1 finger single long tab - right mouse - alernative
- UITapGestureRecognizer *singleFingerSingleLongTap = [[UILongPressGestureRecognizer alloc]
+ UILongPressGestureRecognizer *singleFingerSingleLongTap = [[UILongPressGestureRecognizer alloc]
initWithTarget:self action:@selector(handleSingleFingerSingleLongTap:)];
singleFingerSingleLongTap.delaysTouchesBegan = YES;
singleFingerSingleLongTap.delaysTouchesEnded = YES;
04:25:56 T:218415104 DEBUG: CDVDFactoryCodec: compiled in hardware support: VDADecoder:no VideoToolBoxDecoder:yes CrystalHD:no OpenMax:no
04:25:56 T:218415104 DEBUG: FactoryCodec - Video: - Opening
04:25:56 T:218415104 DEBUG: DllAvUtilBase: Using libavutil system library
04:25:56 T:218415104 DEBUG: DllAvCodec: Using libavcodec system library
04:25:56 T:218415104 DEBUG: DllSwScale: Using libswscale system library
04:25:56 T:218415104 DEBUG: DllAvFilter: Using libavfilter system library
04:25:56 T:218415104 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
04:25:56 T:218415104 DEBUG: FactoryCodec - Video: ff-h264 - Opened
04:25:56 T:218415104 NOTICE: Creating video thread
04:25:56 T:273862656 NOTICE: running thread: video_thread
04:25:56 T:218415104 NOTICE: Opening audio stream: 1 source: 256
04:25:56 T:218415104 NOTICE: Finding audio codec for: 86019
