Full Version: Help to make a small change in the home menu
Hey
Great skin, I've used it since the first version, but with a slight change in the home menu, I use a different program to watch TV from, it is called dvbviewer, so I have always changed the home menu so I can start dvbviewer from there but in the newest version I can't figure out how to edit the home.xml file.
What I usually do is put this text into home.xlm
<item id="13">
<label> LIVE TV </ label>
<onclick> XBMC.System.Exec (c: \ DVBViewer \ dvbviewer.exe) </ onclick>
<icon> special: / / skin / backgrounds / videos.jpg </ icon>
</ item>
So the home menu will look like this: music --- LIVETV --- movies ---- tvshows - etc. .... so when I press the live TV buton XBMC minimize and dvbviewer starts and when I close dvbviewer xbmc comes back. Here is a video from someone else who do the same http://youtu.be/jDY8JaAw5HQ
but in the newest version 3,0 I can't figure out where to put the text.
Hope there is someone who can help me on the way.
Sincerely
Saederup
No need for that anymore with 3.0: go to main menu customizer, go to custom1 for example and enable that. Click next type till it says custom, go to Choose custom and enter XBMC.System.Exec(c:\DVBViewer\dvbviewer.exe)
Choose a custom background, add a widget if you like and done Smile
NICE:-):-)
Thank you!
