Full Version: 2 issues: Screen ratio/Add-ons
I'm a complete newbie and I've tried Googling these two issues and I haven't found a solution. I bought a ready installed XBMC Xbox from eBay and I love it but I'm having two issues I can't get around.
1. The screen ratio is set to 4:3 - when I try changing it to 16:9 the screen goes black but the console remains on. Is there a simple way I can fix that?
2. Add-ons is not listed on the menu - no matter what skin I use - there are Add-ons installed which I can see under Program Plugins but I don't know why I can't see the Add-ons menu as an option - can it be turned on and if yes, how?
Thanks so much in advance!
Xbox discussion has moved to xbmc4xbox.
Sorry - and thank you - I posted my query there.
