Could someone please help with a regex that would work for this please
foo.Part.1...........
Renamed to:
Foo S01E01
works here.
if i wanted to rename it, i wouldnt be wanting a regex
Try:
<advancedsettings>
<tvshowmatching action="append">
<regexp>[\._ \-]p(?:ar)?t[._ -]()([0-9]+)([\._ \-][^\\/]*)</regexp>
</tvshowmatching>
</advancedsettings>
In addition to the above regex, you will also probably need absolute ordering turned on. Set content on the specific show folder, change/set content, click "Settings" and enable "Absolute ordering"
That way it will detect shows without season numbers (and thus have only one season).
gave those a shot, but still wont give it up. thanks for trying though
