I'm making a "Library info update" that will sync your local library with online sources.
I want to know if there is any standard on how the certificates should be named for multiple countries.
So far i found several different notations:
PHP Code:
Rated PG-13
US:PG-13
TV-PG
UK:PG
NL:16
Germany:FSK 16
France:-16
Aeon Nox has several different string compares:
https://github.com/BigNoid/Aeon-Nox/blob...s.xml#L197
I found this source:
http://en.wikipedia.org/wiki/Motion_pict...ing_system
I'm looking to have (or set) a standard for naming convention to put an end to this misery (if possible).
To make all our lives easier.
Suggestion?
What should it be?
PHP Code:
<country code>:rating
<country name>:rating
<country code>:Full blown textual description
<country name>:Full blown textual description
Edit:
Getting rid of the colon would also make it a lot easier for filenaming (illegal characters on some OS).
Example:
It would be great to get rid of the stringcompares and just load pictures, but i must say that the rating also has detailed text of why it has been rated R for example. In Nox we only use it in one place, but I can imagine other skins only use the full text instead of pictures.
I am for
Where are the ratings being scraped from?
They need to be in a format whereby we can simply use them to point to a folder containing all the different types without having to use visible conditions.
eg
<texture>$INFO[ListItem.Certificate,certificates,.png]<texture>
I think you're opening yourself up to a world of hurt but good luck.
i agree with Big_Noid & Hitcher, if we want to do this right, the rating country/value must match the image name.
it's not sane to have several hundreds of variables in the skin just to match the correct rating image.
(2012-05-29, 21:03)olympia Wrote: [ -> ]I am for
(2012-05-29, 21:23)Hitcher Wrote: [ -> ]Where are the ratings being scraped from?
eg <texture>$INFO[ListItem.Certificate,certificates,.png]<texture>
(2012-05-29, 21:27)ronie Wrote: [ -> ]i agree with Big_Noid & Hitcher, if we want to do this right, the rating country/value must match the image name.
All in favor of (they are somewhat listed like this on TMDB):
so like this
Don't see that being a problem.
I'd prefer slash I think:
iso639-1/rating, i.e. uk/ma16 or whatever.
That way you can easily have your images in nicely separated folders?
Ofcourse, these would be the ideal candidates for art packs.
Cheers,
Jonathan
(2012-05-30, 00:08)jmarshall Wrote: [ -> ]I'd prefer slash I think:
Cheers,
Jonathan
Won't cause any problems on different OS?
Whatever is easiest for skinners and still looks good in skins that display the plain text.
Also there are only like 6 images per country so having them all in one folder isn't that awfull.
Still hoping for those artworkpacks. Even if only basic implementation is added for Frodo.
No - XBMC uses sane slashes internally for stuff like this (special://foo/ URL).
(2012-05-31, 06:24)jmarshall Wrote: [ -> ]No - XBMC uses sane slashes internally for stuff like this (special://foo/ URL).
OK so
it is then.
Example
so folder structure should look something like:
PHP Code:
ratingflags/
US/
NL/
DE/
