Full Version: Get desktop on XBMCbuntu
I've just finish to install XBMCbuntu.
During installation, I've been asked to create a user and a password with auto logon.
When my HTPC start, I arrive directly under XBMC and if I close XBMC, I'm on X11 user prompt.
If I use the user defined during installation, XBMC restart.
There is other user defined on combo box (XBMC, XBMCbuntu) but I don't know password as I didn't set them during installation. I've try xbmc password with no success.
How can I log on desktop with my user or another one without having XBMC (to copy files, ...) ?
You log-in as user XBMC (1st box) and session type as XBMCbuntu (2nd box). Leave password field blank.
I need to enter my password, as I have defined one on XBMCbuntu setup.
Now I understand the combo box to log on XBMC or XBMCbuntu.
I think that it should be detailed in WiKi but I didn't find it :S
Its a sticky at the top of this forum....
(2012-05-31, 22:33)mikebzh44 Wrote: [ -> ]I need to enter my password, as I have defined one on XBMCbuntu setup.
