2012-05-31, 22:08
2012-05-31, 23:22
Your going to need to be a little more specific about what you mean but if its what I think you can disable them in skin settings
2012-06-01, 13:04
http://postimage.org/image/3o2jh0q8r/
Those things that are in the background, marked with red arrows. I didn't find any option to disable them. I call them bkgd_frames because they're named like that in the .xpr files in "media" folder.
2012-06-01, 16:10
If you push m to open up the player controls or start on the xbox controller there is an option to disable background animation nested in there somewhere
2012-10-13, 11:48
I have installed jx 720 on ipad but can not move from media ... to system ... please help how to use this on ipad
2012-10-14, 04:37
there is no way your going to use jx720 on an ipad I suggest you just delete the skin and let it revert back to default
