I am installing Windows 8, but got XBMC on my W7 laptop just right. How can I backup XBMC with all add-ons and settings, and apply them to a new install?
you can either use the XBMC backup add-on...or you can simply copy your XBMC roaming folder "C:\Users\(user name)\AppData\Roaming\XBMC"
Thank you. I jumped the gun and used the roaming folder. It worked! Didn't know of the add-on.
I haven't used the add-on yet myself...but its noteworthy that it exists
PS, glad you got it
I run windows 8 too and I love it, you may want to look into
start 8 by stardock...I wouldn't use windows 8 without it
(2012-06-01, 02:01)digitaltomj Wrote: [ -> ]I haven't used the add-on yet myself...but its noteworthy that it exists
PS, glad you got it I run windows 8 too and I love it, you may want to look into start 8 by stardock...I wouldn't use windows 8 without it
Thanks for the tip, but I really like the start menu instead of a start button.
