2012-11-19, 03:51
Thanks for the response Paul. Is there not even an option to mark TV episodes as watched? That is the only thing keeping me from using this skin full time.
(2012-11-19, 01:55)Paul Salem Wrote: [ -> ]Thanks for all the feedback.
I am still working on the changes for Frodo.
Latest version is as usual on the main branch of the git repo.
I will fix all the bugs that are being reported, as well as trying to implement some of the features/changes requested.
(@knewknow, Indicators for unwatched items will be back as an option
Weather on main menu should display fine now if selected)
(2012-11-17, 23:40)patseguin Wrote: [ -> ]I just tried installing the repo on another computer and it said dependencies no it met. What does that mean?
(2012-11-19, 03:51)patseguin Wrote: [ -> ]Thanks for the response Paul. Is there not even an option to mark TV episodes as watched? That is the only thing keeping me from using this skin full time.
(2012-11-19, 04:54)knewknow Wrote: [ -> ](2012-11-19, 01:55)Paul Salem Wrote: [ -> ]Thanks for all the feedback.
You sir are doing a great job with this skin. Thanks for being so accommodating. Have you noticed a large performance hit in Frodo with refocus big (choppy menus etc.)?
(2012-11-19, 18:38)Julestop Wrote: [ -> ]Hi,
I've been using ReFocus BIG for a while now and I've been loving it.
I am wondering if there is a way of removing the blue fading on the left side of the home screen? It looks very weird when I have black fanart... and generally blocks part of my fanart backgrounds.
Thank!
(2012-11-19, 19:04)patseguin Wrote: [ -> ]I love the skin, but I have multiple issues which I don't know if are frodo related or me not understanding the skin.
#1, I can get fanart to display for my movies menu item or tv shws menu item.
#2 TV shows to get mark as watched like the default skin does. Does the skin support this but it is just broken.
#3 I can find a ZIP repo for this skin. Only a zip of the actual skin. Where do I find the repos so I stay updated?
#4 I can't find any menu to exit XBMC, reboot, etc. Does the skin just not allow you to exit XBMC?
(2012-11-19, 23:07)tripkip Wrote: [ -> ]I cannot get this skin installed on Frodo with OpenElec.
The install from zip complains about not meeting dependencies.
There is no possibility to extract the zip directly in the addons folder with openelec.
I manually downloaded:
-tv.show.next.aired
-artwork.downloader
-artistslideshow
-globalsearch
-skin.widgets
Fixed by installing randomlastitems plugin.
(2012-11-19, 23:40)Weavus Wrote: [ -> ]Hi,
Found a couple of issues
1) PVR channel icons are not showing in the Timeline EPG view
2) After 30 seconds or so the EPG data sometimes vanishes
And have a couple of requests
3) Can you allow the option of showing tv posters OR episode thumbs in the recent TV widget
4) Can you allow the option of showing movie posters OR fanart in the recent TV widget
Thanks for the great skin!
(2012-11-19, 02:42)arokh Wrote: [ -> ]Any way to remove weather report and clock symbol on xperience1080 info OSD?
EDIT: Found it, just remove any occurence of <include>OSDWeatherClock</include>.
EDIT2: Did thumbnails small grid option disappear with latest git?
(2012-11-20, 05:45)patseguin Wrote: [ -> ]BTW #2 for enable global fanart doesn't work. Still no fanart fot movies or tv shows. I['ll chalk it up to broken as well.
(2012-11-20, 11:20)ElPolo Wrote: [ -> ]I love your skin, great job !
I had to hide fanarts from films or TV show views, because there was a real performance impact from Eden version of ReFocus (really, i use a USB Key for the system), sometimes XBMC hang for 2 seconds before showing fanarts, or moving to next poster in view.
Disabling fanarts in view make XBMC much more fluid.
Is this normal ?
