2012-11-23, 11:56
(2012-11-19, 23:40)Weavus Wrote: [ -> ]3) Can you allow the option of showing tv posters OR episode thumbs in the recent TV widget
4) Can you allow the option of showing movie posters OR fanart in the recent TV widget
Thanks for the great skin!
Done.
(2012-11-20, 17:58)Weavus Wrote: [ -> ]Any way I can make the homescreen fanart blend with the theme like the movie/tv section?
I have the following skin settings enabled:
Theme "metal"
Homescreen -> customize backgrounds
> Use original wallpaper: yes
> Enable global fanart background: yes
Homescreen -> widgets
> Light Opacity
Done too. Now if you are using the original wallpaper option, the overlay to highlight the widgets should not be displayed. Also, now the homescreen fanart blending with the theme should be pretty similar to the one in the movie/tv section
(2012-11-20, 19:58)ElPolo Wrote: [ -> ]You're definitely right, opacity did not change anything, but disabling extra fan-art in media view make XBMC fluid like water
I will wait for your improvements on this.
Many thanks !
I have implemented a few more tweaks to extrafanart. It should be faster now.
(2012-11-20, 22:34)Jaypeg Wrote: [ -> ]In deck view for movies, banner images is used instead of poster images. Just a small heads up. (In lastest git version)
PHP Code:<texture diffuse="frames/frame_Portrait-mask.png" fallback="thumbs/movie_portrait.jpg">$INFO[ListItem.Art(banner)]</texture>
I suppose it should be:
PHP Code:<texture diffuse="frames/frame_Portrait-mask.png" fallback="thumbs/movie_portrait.jpg">$INFO[ListItem.Art(poster)]</texture>
Thanks for reporting. It is fixed now.
(2012-11-20, 22:38)tripkip Wrote: [ -> ]Hey Paul, it seems that it is possible to host a repository from Google Code or Github!
http://wiki.xbmc.org/index.php?title=Uno...positories
Thanks. Actually that was my intention when creating the Google Code page for reFocus Big.
Still didn't have time though to setup the repo in there. I hope that when things get more stable I will be able to do it.
(2012-11-21, 08:33)Frozin Wrote: [ -> ]Hi Paul,
Love the mod, just noticed something with the recommended widget. It appears to be showing the wrong season # and episode #. The episode name is correct along with the description. Don't know if this is skin related or xbmc related or if its something I did.
thanks again for a great mod.
True. It has been fixed now.
(2012-11-22, 17:04)Dingens Wrote: [ -> ]Hey
thanks a lot, great MOD.
Two questions:
If you play a music track and hit TAB, you get the full screen view. If the title of the track is long, it's not shown completely and, in contrast to other skins, it also doesn't scroll. Any chance to get it scrolling?
And, in the same view, a progress bar would be nice. Any chance for that?
Thanks a million
Rolf
I will get that fixed and I will check on the progress bar implementation.
(2012-11-22, 23:09)fma965 Wrote: [ -> ]is it just me or no matter whether the weather home item is enabled or not it still shows, latest git version.
This should have been fixed some time ago already.
Can you please confirm what version are you running?
You can check it under settings, appearance, skin, and then check for the number under the skin's name.
Latest should be 0.84.2
(2012-11-23, 09:21)Dennis1984 Wrote: [ -> ](2012-11-17, 18:27)Dennis1984 Wrote: [ -> ]I'm still using 'normal' ReAlaska, but does anyone know how to show albums only once?
I don't want the the album list under artist to repeat.
I'm sorry to repeat my own question, but is there someone who knows the answer to this? I don't want the albums to appear multiple times in this view.
Try changing the following option in ViewSlide.xml,
from wraplist to fixedlist.
(2012-11-23, 10:49)bakito Wrote: [ -> ]hello,
just one question, how can I make the animation in poster view more slow?
I feel it's too fast for me! ( yes I'm slow...)
thx!
cheers
Just to confirm, you mean the slide view, right?
_____________________________________________________________________________
I have been implementing several changes lately on the widgets section.
Now you can disable any widget, and there are more options to display posters on recent tv shows, or fanart on recent/recommended movies.
Also, it is possible to disable the menu shade on the left of the home menu. It will be off automatically when viewing the fanart in any widget item so that the fanart gains more prominence.
Besides, I have added a new version of the Melted Chocolate theme which Ely51um has kindly provided.
