2012-12-11, 04:57
(2012-12-09, 23:16)zeppy Wrote: [ -> ]I'll check out the code and see what I can do.
yep. that version didn't work for me either. Thanks for looking into it zeppy.
(2012-12-13, 23:38)canadave Wrote: [ -> ]I upgraded to Frodo RC1, and now I'm getting a message saying that reFocus BIG's repository has been marked as broken, dependencies not met. ??
EDIT: Never mind...I did Check Updates and also did Force Refresh on the repo, and now it seems to be working fine. Odd..
(2012-12-13, 23:54)rd1979 Wrote: [ -> ]There's a few minor bug I'm experiencing.....
Have you noticed any odd issues with movie posters disappearing after you play one? Only to have it (sometimes) later reappear?
I'm not sure if this RC is to blame, or the skin, but I think its more likely the skin from the way things are happening.
(2012-12-14, 03:50)canadave Wrote: [ -> ](2012-12-13, 23:54)rd1979 Wrote: [ -> ]There's a few minor bug I'm experiencing.....
No, I haven't noticed that. I am having some issues with about 10-15% of my thumbnails not appearing. I'm not sure at all what's happening there. But the specific issue you describe, I am not experiencing.
(2012-12-14, 19:20)taalas Wrote: [ -> ](2012-12-13, 23:54)rd1979 Wrote: [ -> ]There's a few minor bug I'm experiencing.....
I have noticed the same thing with beta 2. Haven't had the time to really debug yet, but it definitely happens to me too...
(2012-12-15, 00:51)rd1979 Wrote: [ -> ]I deleted all the Textures*.db files in my userdata folder (after backing them up of course) and that seemed to fix things for me, after I cycled through all the posters for them to load up.
(2012-12-15, 11:13)taalas Wrote: [ -> ]Good to know. I will give this a try. One more thing that happens on my machine:
When starting videos directly from the file view (I do this sometimes when accessing temp directories that are not part of the scraped source folders) I noticed that these don't have any posters either. These used to be generated from the file when first accessing them - I think by taking a screen from about 10% into the file...
138448896 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnSeek
01:09:55 T:177356800 DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_SYNCHRONIZE
01:09:55 T:177889280 DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_SYNCHRONIZE
01:09:55 T:177889280 DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_RESYNC(212472000.000000, 1)
01:09:55 T:1054203288 DEBUG: XBMCPureController: Button press remoteAction = 7
01:09:55 T:171945984 DEBUG: CDVDPlayer::HandleMessages - player started 1
01:09:56 T:171945984 DEBUG: ffmpeg[A3FB000]: [NULL] Invalid and inefficient vfw-avi packed B frames detected
01:09:56 T:177356800 DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_RESYNC(212462250.000000, 0)
01:09:56 T:177356800 INFO: CDVDPlayerVideo - Stillframe left, switching to normal playback
01:09:56 T:171945984 DEBUG: CDVDPlayer::HandleMessages - player started 2
01:09:56 T:171945984 DEBUG: CDVDPlayer::SetCaching - caching state 0
01:09:56 T:177889280 DEBUG: CDVDPlayerAudio:: Discontinuity - was:212452017.625000, should be:212544000.000000, error:91982.375000
01:09:56 T:177889280 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
01:09:56 T:177356800 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
01:09:57 T:1054203288 DEBUG: XBMCPureController: Button press remoteAction = 1
01:09:57 T:138448896 DEBUG: CWinEventsIOS: Button press keyID = 6
01:09:57 T:138448896 NOTICE: CDVDPlayer::CloseFile()
01:09:57 T:138448896 NOTICE: DVDPlayer: waiting for threads to exit
01:09:57 T:171945984 NOTICE: CDVDPlayer::OnExit()
01:09:57 T:171945984 NOTICE: DVDPlayer: closing audio stream
01:09:57 T:171945984 NOTICE: Closing audio stream
01:09:57 T:171945984 NOTICE: Waiting for audio thread to exit
01:09:57 T:177889280 NOTICE: thread end: CDVDPlayerAudio::OnExit()
01:09:57 T:171945984 NOTICE: Closing audio device
01:09:57 T:171945984 ERROR: CCoreAudioUnit::Close: Unable to disconnect AudioUnit. Error = -10860
01:09:57 T:171945984 DEBUG: CCoreAudioAEStream::~CCoreAudioAEStream - Destructed
01:09:57 T:171945984 NOTICE: Deleting audio codec
01:09:57 T:171945984 NOTICE: DVDPlayer: closing video stream
01:09:57 T:171945984 NOTICE: Closing video stream
01:09:57 T:171945984 NOTICE: waiting for video thread to exit
01:09:57 T:177356800 NOTICE: thread end: video_thread
01:09:57 T:171945984 NOTICE: deleting video codec
01:09:57 T:171945984 NOTICE: CDVDPlayer::OnExit() deleting demuxer
01:09:57 T:171945984 NOTICE: CDVDPlayer::OnExit() deleting input stream
01:09:57 T:171945984 DEBUG: CNFSFile::Close closing file volume3/movies/Trailer Park Boys - The Movie (2006)/Trailer Park Boys - The Movie (2006).avi
01:09:57 T:171945984 DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
01:09:57 T:171945984 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
01:09:57 T:138448896 NOTICE: DVDPlayer: finished waiting
01:09:57 T:138448896 DEBUG: LinuxRendererGL: Cleaning up GL resources
01:09:57 T:138448896 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
01:09:57 T:138448896 DEBUG: ------ Window Deinit (VideoFullScreen.xml) ------
01:09:57 T:166572032 DEBUG: GetImageHash - unable to stat url
01:09:57 T:138448896 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
01:09:57 T:138448896 DEBUG: ------ Window Init (MyVideoNav.xml) ------
01:09:57 T:138448896 DEBUG: CGUIMediaWindow::GetDirectory (videodb://1/2/)
01:09:57 T:138448896 DEBUG: ParentPath = [videodb://1/2/]
01:09:57 T:138448896 DEBUG: Loading fileitems [videodb://1/2/]
01:09:58 T:138448896 DEBUG: -- items: 199, directory: videodb://1/2/ sort method: 0, ascending: false
01:09:59 T:140853248 DEBUG: DoWork - took 166 ms to load /var/mobile/Library/Preferences/XBMC/addons/skin.refocus.big/media/thumbs/movie_portrait.jpg
01:09:59 T:138448896 NOTICE: CDVDPlayer::CloseFile()
01:09:59 T:138448896 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
01:09:59 T:138448896 NOTICE: DVDPlayer: waiting for threads to exit
01:09:59 T:138448896 NOTICE: DVDPlayer: finished waiting
01:09:59 T:138448896 DEBUG: LinuxRendererGL: Cleaning up GL resources
01:09:59 T:166572032 DEBUG: DoWork - Saving file state for video item nfs://192.168.1.211/volume3/movies/Trailer Park Boys - The Movie (2006)/Trailer Park Boys - The Movie (2006).avi
01:09:59 T:166572032 DEBUG: Mysql execute: update files set playCount=NULL,lastPlayed='2012-12-16 01:09:59' where idFile=1379
01:09:59 T:166572032 DEBUG: CAnnouncementManager - Announcement: OnUpdate from xbmc
01:09:59 T:166572032 DEBUG: GOT ANNOUNCEMENT, type: 16, from xbmc, message OnUpdate
01:09:59 T:138448896 DEBUG: ------ Window Deinit (DialogSeekBar.xml) ------
01:09:59 T:166572032 DEBUG: Mysql execute: insert into bookmark (idBookmark, idFile, timeInSeconds, totalTimeInSeconds, thumbNailImage, player, playerState, type) values(NULL,1379,213.500015,5689.225098,'','DVDPlayer','', 1)
01:09:59 T:166572032 DEBUG: Mysql execute: INSERT INTO settings (idFile,Deinterlace,ViewMode,ZoomAmount,PixelRatio, VerticalShift, AudioStream,SubtitleStream,SubtitleDelay,SubtitlesOn,Brightness,Contrast,Gamma,VolumeAmplification,AudioDelay,OutputToAllSpeakers,ResumeTime,Crop,CropLeft,CropRight,CropTop,CropBottom,Sharpness,NoiseReduction,NonLinStretch,PostProcess,ScalingMethod,DeinterlaceMode) VALUES (1379,1,0,1.000000,1.000000,0.000000,-1,-1,0.000000,1,50.000000,50.000000,20.000000,0.000000,0.000000,0,0,0,0,0,0,0,0.000000,0.000000,0,0,1,0)
01:10:04 T:1054203288 DEBUG: XBMCPureController: Button press remoteAction = 6
01:10:04 T:138448896 DEBUG: CWinEventsIOS: Button press keyID = 3
01:10:07 T:1054203288 DEBUG: XBMCPureController: Button press remoteAction = 7
01:10:07 T:138448896 DEBUG: CWinEventsIOS: Button press keyID = 4
01:10:27 T:138448896 DEBUG: SECTION:UnloadDelayed(DLL: libmad.0.dylib)
01:10:27 T:138448896 DEBUG: Unloading: libmad.0.dylib
01:10:37 T:138448896 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib-arm-osx.so)
01:10:37 T:138448896 DEBUG: Unloading: ImageLib-arm-osx.so
01:11:32 T:138448896 NOTICE: NFS is idle. Closing the remaining connections.
01:12:02 T:138448896 DEBUG: SECTION:UnloadDelayed(DLL: libnfs.1.dylib)
01:12:02 T:138448896 DEBUG: Unloading: libnfs.1.dylib
