2013-02-27, 01:21
s1mp3,
use channel up/down buttons on your remote to jump from page to page.
If you want to scroll using letters, you have to set up your keymap.xml to use JumpSMS style numbering for your remote. that way for example, you can jump to titles/artists starting with C by pushing the number 2, three times on your remote.
There's plenty of info out there on how to do this.
Start here:
see http://wiki.xbmc.org/index.php?title=Keyboard.xml
There's a good thread on this topic here:
http://forum.xbmc.org/showthread.php?tid=120927
If you need more info/help with this, then you need to post on over in the XBMC General forum, as it's got nothing to do with the skin.
Hope this helps,
Cheers.
Start here:
Hope this helps,
Cheers.
