Full Version: Jerky animation on iPad 3?
Hello all.
Not sure how I should go about reporting this, but some of my video files (mainly animation) have jerky motions at moments on the ipad3.
Plays fine on my laptop in XBMC and other applications.
Here are the video details of the file in question -
Writing application: mkvmerge v1.5.0
Writing library: libebml v0.7.5 + libmatroska v0.7.7
Writing library: x264 core 54 rev 600
Format: AVC
Format profile: [email protected]
Codec ID: H264
Bit rate: 1 229 Kbps
Width: 704 pixels
Height: 396 pixels
Display aspect ration: 16:9
Frame rate: 23.976 fps
Scan type: Progressive
Bits/(Pixel*Frame): 0.184
Bit depth: 8 bity
Color Space: YUV
Chroma subsampling: 4:2:0
Audio Format: Vorbis
Codec ID: A_VORBIS
Bit rate: 112Kbps
Sampling rate: 48.0KHz
Compression mode: Lossy
Writing library: libVorbis 1.0
If you need a sample of the video, please let me know.
If there is any way I can fix.....if not, it's ok.
