Full Version: [Solved] Is there any way to convert the .tbn files to .dds ?
I know its done automatically by xbmc if they are needed but I've a huge library and for the AppleTv (gen 1) it takes forever. It consantly stays on 100%cpu usage while doing that.
Can I somehow convert the files manually with my much stronge main PC ? (With ATI gpu)
Later I would just simply copy back the converted files to the AppleTv.
Thank you !
# EDIT : Found the answer.
