Full Version: latest pulse-eight build - channel freezing issues
Hi All,
I have just updated to the latest openelec build and I seem to be having a lot of freezing and crashing issues
I have just downgraded http://packages.pulse-eight.net/OpenELEC...74.tar.bz2 to stop this happening (dated from the 2nd May).
I am just wondering what are the main things that have changed so I know where to post the error log?
Thanks all.
What version is everyone else using at the moment?
Same problem here.
The 9974 version is working fine. But the newest build is giving alot of problems.
Alot of crashing (mostly during channel skipping)
Stutter in video files that played fine before.
The channel numbering from the backend isn't working (tvheadend)
I have also tried the beta versions from the openelec.tv site. But they have the same issues.
(2012-06-03, 21:35)Johnnygo Wrote: [ -> ]Same problem here.
Yes, at least it not just my setup. Do have some idea what changes this could be so we can raise a bug.
Thanks,
I'm running some tests, and when watching live tv, I see alot of errors in the logfile:
20:29:32 T:2700249920  NOTICE: -------- drop output
20:29:32 T:2668641088   ERROR: CMixer::InitCycle - interlace method not supported
20:29:32 T:2700249920 WARNING: CVDPAU::DrawSlice - VdpDecoderRender long decoding: 35 ms, dec: 1, proc: 3, rend: 0
20:29:32 T:2700249920   ERROR: Previous line repeats 2 times.
20:29:32 T:2700249920 WARNING: CVDPAU::DrawSlice - VdpDecoderRender long decoding: 36 ms, dec: 1, proc: 3, rend: 0
20:29:32 T:2700249920 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
20:29:33 T:2700249920   ERROR: Previous line repeats 1 times.
20:29:33 T:2700249920 WARNING: CVDPAU::DrawSlice - VdpDecoderRender long decoding: 39 ms, dec: 1, proc: 2, rend: 0
20:29:33 T:2668641088   ERROR: CMixer::InitCycle - interlace method not supported
20:29:33 T:2700249920   ERROR: Previous line repeats 2 times.
20:29:33 T:2700249920 WARNING: CVDPAU::DrawSlice - VdpDecoderRender long decoding: 32 ms, dec: 1, proc: 2, rend: 0
20:29:33 T:2700249920 WARNING: CVDPAU::DrawSlice - VdpDecoderRender long decoding: 35 ms, dec: 2, proc: 2, rend: 0
20:29:33 T:2700249920   ERROR: Previous line repeats 5 times.
20:29:33 T:2700249920 WARNING: CVDPAU::DrawSlice - VdpDecoderRender long decoding: 33 ms, dec: 1, proc: 3, rend: 0
20:29:33 T:2700249920 WARNING: CVDPAU::DrawSlice - VdpDecoderRender long decoding: 32 ms, dec: 3, proc: 0, rend: 0
20:29:33 T:2700249920   ERROR: Previous line repeats 4 times.
20:29:33 T:2700249920 WARNING: CVDPAU::DrawSlice - VdpDecoderRender long decoding: 34 ms, dec: 1, proc: 3, rend: 0
20:29:34 T:2700249920   ERROR: Previous line repeats 4 times.
20:29:34 T:2700249920 WARNING: CVDPAU::DrawSlice - VdpDecoderRender long decoding: 34 ms, dec: 1, proc: 2, rend: 0
20:29:34 T:2668641088   ERROR: CMixer::InitCycle - interlace method not supported
20:29:34 T:2700249920  NOTICE: -------- drop output
20:29:34 T:2700249920   ERROR: Previous line repeats 1 times.
20:29:34 T:2700249920 WARNING: CVDPAU::DrawSlice - VdpDecoderRender long decoding: 31 ms, dec: 1, proc: 2, rend: 0
20:29:34 T:2700249920   ERROR: Previous line repeats 2 times.
20:29:34 T:2700249920 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
20:29:34 T:2700249920 WARNING: CVDPAU::DrawSlice - VdpDecoderRender long decoding: 33 ms, dec: 1, proc: 2, rend: 0
20:29:35 T:2700249920   ERROR: Previous line repeats 2 times.
20:29:35 T:2700249920 WARNING: CVDPAU::DrawSlice - VdpDecoderRender long decoding: 34 ms, dec: 1, proc: 2, rend: 0
20:29:35 T:2668641088   ERROR: CMixer::InitCycle - interlace method not supported
20:29:35 T:2700249920   ERROR: Previous line repeats 3 times.
20:29:35 T:2700249920 WARNING: CVDPAU::DrawSlice - VdpDecoderRender long decoding: 37 ms, dec: 1, proc: 3, rend: 0
20:29:35 T:2700249920   ERROR: Previous line repeats 5 times.
20:29:35 T:2700249920 WARNING: CVDPAU::DrawSlice - VdpDecoderRender long decoding: 31 ms, dec: 3, proc: 0, rend: 0
Logfile is filling rapidly with these errors. Is there something changed in the vdpau drivers?
When I play an 1080p24 file, it's complete unwatchable. Got this from the log:
20:32:04 T:2642410304   ERROR: CMixer::InitCycle - interlace method not supported
20:32:04 T:2654989120   ERROR: Previous line repeats 1 times.
20:32:04 T:2654989120 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
20:32:04 T:2683304768 WARNING: CVDPAU::DrawSlice - VdpDecoderRender long decoding: 31 ms, dec: 3, proc: 0, rend: 0
20:32:04 T:2654989120   ERROR: GetDelay - snd_pcm_delay, alsa error: -32 - Broken pipe
20:32:04 T:2683304768  NOTICE: -------- drop output
20:32:04 T:2654989120   ERROR: Previous line repeats 2 times.
20:32:04 T:2642410304  NOTICE: Previous line repeats 1 times.
20:32:05 T:2654989120   ERROR: GetDelay - snd_pcm_delay, alsa error: -32 - Broken pipe
20:32:05 T:2683304768  NOTICE: -------- drop output
20:32:05 T:2642410304   ERROR: CMixer::InitCycle - interlace method not supported
20:32:05 T:2683304768   ERROR: Previous line repeats 1 times.
20:32:05 T:2654989120 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
My system is an atom 230 cpu (single core 1.60ghz) and ION1 (ION/INTEGRATED/SSE2)
My other system has exactly the same problem: atom 550 cpu (dual core) and ION2.
Both systems play these files and live tv without problems on the early version.
Here is the xbmc debug log: http://46.102.240.177/error_xbmc.log Scroll down to see the errors.
Johnnygo, I taked to the OE guys, they took accidently this outdated version version with the XvBA patches. Nevertheless, it was use to work. "interlace method not supported" may be caused by outdated tv or video database. Have you tried to delete the entire .xbmc folder?
Thanks, I will try a fresh install (no upgrade) tomorrow. And see if it has the same behavior.
ahhhh the famous "GetDelay - snd_pcm_delay, alsa error: -32 - Broken pipe"...
well probably vdpau related.
http://forum.xbmc.org/showthread.php?tid=128457
