Full Version: xbmc and sabnzb
is it possible to have sabnzb start running in the background when i turn my htpc on using xbmcbuntu?
yes
any chance of pointing me in the right direction ive been searching but cant find anything
If its installed try
sudo update-rc.d sabnzbd defaults
From a terminal.
(2012-06-04, 01:41)teeduebb Wrote: [ -> ]If its installed try
From a terminal.
thank you teeduebb thats a bit more helpful, mr.sparkle if you cant be arsed then just dont bother replying.
i count the time ive spent trying to set all this up in days now not hours so a simple reply with a bit of info is really appreciated thank you
