No need to mess with PyAMF anymore, there's a script module in the main repo now.
I worked on this some a while back then kind of forgot about it
I added a "choose" setting that lets you pick from the available streams, usually one of them will work
Don't really have time to do anything with this add-on at the moment but I updated github and uploaded a zip here ->
https://divingmules-repo.googlecode.com/...-0.0.2.zip
Consider this still a work in progress, expect some issues.
Understood, but FYI...CBC +2 is still not working! THX
Hello,
I installed your plugin to watch ustream channels but it doesnt do anything. If I see xbmc.log I get:
07:19:14 T:3472 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.KeyError'>
Error Contents: (u'\xfa',)
File "C:\Documents and Settings\Administrator\Application Data\XBMC\addons\plugin.video.ustream\default.py", line 408, in <module>
categories()
File "C:\Documents and Settings\Administrator\Application Data\XBMC\addons\plugin.video.ustream\default.py", line 65, in categories
addDir(i[0], base+i[1], 1, icon)
File "C:\Documents and Settings\Administrator\Application Data\XBMC\addons\plugin.video.ustream\default.py", line 334, in addDir
u=sys.argv[0]+"?url="+urllib.quote_plus(url)+"&mode="+str(mode)+"&name="+urllib.quote_plus(name)
File "F:\XBMC\system\python\Lib\urllib.py", line 1232, in quote_plus
return quote(s, safe)
File "F:\XBMC\system\python\Lib\urllib.py", line 1224, in quote
res = map(safe_map.__getitem__, s)
KeyError: (u'\xfa',)
07:19:14 T:3276 WARNING: CWin32DirectSound::GetSpace - buffer underrun - W:0, P:17208, O:38808.
07:19:14 T:3276 WARNING: CWin32DirectSound::GetSpace - buffer underrun - W:17640, P:34288, O:10584.
07:19:14 T:3276 WARNING: CWin32DirectSound::GetSpace - buffer underrun - W:10584, P:27000, O:3528.
07:19:14 T:3276 WARNING: CWin32DirectSound::GetSpace - buffer underrun - W:7056, P:22624, O:3528.
07:19:14 T:3276 WARNING: CWin32DirectSound::GetSpace - buffer underrun - W:24696, P:41672, O:21168.
07:19:15 T:3976 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.ustream/
07:19:15 T:3976 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.ustream/) failed
07:19:15 T:3172 NOTICE: Thread Background Loader start, auto delete: false
Could you help me?
Best Regards.
Maybe if you don't mind getting you hands dirty.
Find line 65 in the above file and change it from
to
addDir(i[0].encode('utf-8', 'ignore'), base+i[1], 1, icon)
Hello divingmule,
Never mind, it works, I see categories and channels but after select a channel, right now I get
Error Contents: cannot concatenate 'str' and 'tuple' objects
on lines
addon_log('Play URL: '+play_url)
item = xbmcgui.ListItem(path=play_url)
I tried disabling the log write and reencoding to unicode with (I have no idea about python but.....)
item = xbmcgui.ListItem(path=play_url).encode('unicode', 'ignore')
but I get a mess about errors on xbmc.log
Anyway........on the other side I'm writting a vbs plugin for my htpc software (I'm just checking for xbmc cause I bought a new tablet ) and I'm able to get and play several streams. I get channel id and related amf file to. The problem is sometimes I see status channel as offair (and of course it seems to not be). Then I started to looking for in m3u8 file unsuccesfully .............
Could you give a clue to point in the right way?
Thanks dirty hack is working for me.
in some reason i couldn't find this channel :
http://www.ustream.tv/channel/hm-hdtv3 from this user: leengeap
i did manual add this in categories(): addDir('HM HDTV-3', '13206990', 4, search_icon)
and this: if play_url:
print play_url xbmc.Player( xbmc.PLAYER_CORE_DVDPLAYER ).play(play_url)
it's working but i couldn't stop it's just looping. that streaming help thanks.
Try changing the addDir to addLiveLink, then remove the other stuff you added.
yes, it's working , but this error video message coming: ustream we are optimizing the stream for your device, ,,,
then i stop and wait for a bit and start play again then it'll work, help again thanks.?
Thats interesting, so you get the 'optimizing the stream' video, then retry and get the real stream?
Yes, what should I do
I don't know... can you check the log and see if the m3u8 url is the same each time?
I've been getting script failure for this plugin this week. Everything was working good last week when I used it. Has there been some change on Ustream's side that has changed things for this script?
