Full Version: Is anyone using these controls?:
a glance through the source of pm3, and the other common v1.3 compatible skins out there shows that these two control types:
buttonm
spinbutton
are not in use. i'm planning on removing them, but will not ofcourse do so if you guys are using them or planning to.
note that the spinbutton is not the spincontrol (page up/downs) or spincontrolex (settings spin control)
let me know. will definitely get rid of them at the next skin version increment, which won't work until the next xbmc release hits the streets (at least a month away, probably more).
cheers,
jonathan
never used at all, clean it up!
:p :d
