Hello all,
this is my first post with a simple question that I couldnt find an answer for in the forum.
how do I remove a video/TV/Music source (location) that I already added in xbmc?
Welcome
select that source and pull up the context menu (keyboard "C")
then do "" remove source"
you can also go to the userdata folder and delete the source.xml file
(2012-06-07, 13:46)EZ1976 Wrote: [ -> ]you can also go to the userdata folder and delete the source.xml file
Don't point some one to the difficult way if you can do it the easy way
(2012-06-07, 13:25)Martijn Wrote: [ -> ]Welcome
I am using Xtreamer ultra 2, is there a way to do that using the remote control?
Should be the "title" button, I think.
(2012-06-07, 15:19)Martijn Wrote: [ -> ] (2012-06-07, 13:46)EZ1976 Wrote: [ -> ]you can also go to the userdata folder and delete the source.xml file
I ended up sshing my xtreamer box and went to that director and deleted it as per the instruction, I found it easier than doing it through the remote control.
